Mechanical Linkage Statics Problem
In summary, the conversation discusses a problem with finding the load torque around a fixed pin joint caused by the piston force F_p. The joint between element 2 and 3 is constrained to move vertically and the angle of element 4 to the global vertical is one-third of the angle of element 5. The solution involves balancing forces and moments on elements 3, 4, and 5, and determining the resultant torque about the fixed pin joint. The person seeking guidance is unsure whether to combine the torques or apply them separately. They also mention the importance of being clear about which free body is being described when applying equilibrium equations.
Mikol91
Hi guys,
I've been trying to resolve the following problem but have worked myself into a frenzy and would appreciate some guidance on how to proceed but also to set my mind completely clear.
The problem is to find the load torque around the fixed pin joint arising from the piston force F_p.
The Joint between element 2 and 3 (hereon J23) is constrained to move vertically as per the diagram.
The angle of element 4 to the global vertical is constrained to be one-third that of element 5 to the same reference. This is achieved in reality by a gear in mesh with a fixed (wrt the engine block) ring gear.
The partial solution is on the RHS of the diagram. I have propagated F_c through element 3 as a simple axial force. At link 4, balancing the input force (F_c4) requires a force F_c5 at J45. This constitutes a couple and generates a moment. To balance moments on the element a reactionary torque T_4,r is necessary. It is argued that this torque must be generated by the connection to element 5.
Similar to element 4, the force upon element 5 must be reacted at the fixed pin joint. This again creates a moment that must be balanced. The required balancing moment is designated T_load.
My problem is how to combine the moment analyses of elements 4 and 5 to find the resultant torque about the fixed pin joint. Do I simply place T_4,r on element 5 and balance moments?
e.g.
ƩM = T_5 - T_4 - T_load
(where T_5 is the torque arising from the forces upon element 5)
Or should T_4 be added to T_5? This is where my brain starts to boil.
I believe the problem lies in attempting to transmit a moment from one body to another through a pivot joint. However, I would not be surprised if there is a bigger problem at play here.
Any assistance would be kindly appreciated. Thanks.
I think the problem might be that, in considering equilibrium, you are including both forces and moments at the same time, but the torques actually arise from the eccentric forces. So, what would the torque at the bottom be due just to Fn at the top? Another way of ;looking at it is: what is the component of Fc6 perpendicular to L5? As either approach should give the answer you seek, I suggest you do it both ways and you should get the same answer. When looking at these problems you need to be very very clear about which free body you are describing when applying equilibrium equations. In your case, you have combined diagrams, and your confusion could have arisen from that.
FAQ: Mechanical Linkage Statics Problem
1. What is mechanical linkage statics problem?
Mechanical linkage statics problem refers to the study and analysis of the forces and torques acting on a mechanical linkage system in a state of static equilibrium. This involves finding the unknown forces and moments in a system of interconnected rigid bodies, subject to external loads and constraints.
2. What are the key principles of mechanical linkage statics?
The key principles of mechanical linkage statics include Newton's laws of motion, the principle of virtual work, and the concept of equilibrium. These principles are used to analyze and solve problems involving mechanical linkages.
3. How is mechanical linkage statics applied in real-world scenarios?
Mechanical linkage statics is applied in various engineering fields, such as robotics, automotive design, and mechanical engineering. It is used to design and analyze mechanisms and machines, ensuring their stability and efficiency.
4. What are the common types of mechanical linkages?
The common types of mechanical linkages include four-bar linkages, slider-crank mechanisms, and gear trains. These linkages are used to transmit motion and force between two or more components in a mechanical system.
5. What are the challenges in solving mechanical linkage statics problems?
Solving mechanical linkage statics problems can be challenging due to the complex geometry and multiple unknowns involved. It requires a thorough understanding of the principles and equations involved, as well as the ability to visualize and analyze the system in a systematic manner.
