MHB Mechanical Part Defects in Lot of 500 Pieces
  • Thread starter Thread starter paulmdrdo1
    Mechanical
Mechanical parts can exhibit defects such as insufficient tensile strength, burrs, or unacceptable diameter, with specific counts of each defect noted in a lot of 500 pieces. The discussion highlights the complexity of calculating the total number of defective parts due to overlapping defects. A Venn diagram approach is suggested, starting from the center where all three defects intersect, and working outward to avoid double counting. The inclusion-exclusion principle is also recommended as a straightforward method for determining the total number of defective parts. Understanding these methods is crucial for accurately assessing the quality of the mechanical parts.
paulmdrdo1
A certain mechanical part of a machine can be defective because it has one or more out of
three possible defects: insufficient tensile strength, a burr or a diameter outside of tolerance
limits. In a lot of 500 pieces
19 have tensile strength defect,
17 have a burr,
11 have an unacceptable diameter,
12 have tensile strength and burr defects,
7 have tensile strength and diameter defects,
5 have burr and diameter defects,
2 have all three defects.
I have tried creating venn diagram to sove this but I end having a convoluted solution. Can you help go about using a more managable method? Regards!
Mathematics news on Phys.org
17 have a burr,
Hi paulmdrdo,
You want to draw a venn diagram like this:
Notice that there are 7 regions in this diagram. The trick to solving these problems is to start in the middle and work your way out. Otherwise the double and triple counting can be quite the headache. So we know the number with all three defects is 2. That two goes in the middle. Now you can label each circle as you wish. Call one tensile strength defect, another burr, and the last one unacceptable diameter. It doesn't matter which way you label them.
We know that 5 have burr and diameter defects. If they have burr and diameter, then the group in the middle counts right since they have all three right? So 5-2=3 have JUST burr and diameter defects. Lastly, 17 total have burr. We've already accounted for those with all three defects and two of them. So that leaves 17-2-3=12 with JUST burr.
You repeat the process for the other two, starting in the middle. It won't add up to 500 but that makes sense in the context of the problem since these are defects.
You can also use the inclusion-exclusion principle, which avoids geometrical intuition and makes finding the total number of defective parts very straightforward. Namely,
|A_1\cup A_2\cup A_3|=|A_1|+|A_2|+|A_3|-|A_1\cap A_2|-|A_1\cap A_3|-|A_2\cap A_3|+|A_1\cap A_2\cap A_3|.
Here $A_1$, $A_2$, $A_3$ are sets, $|A|$ is the number of elements in $A$, $A\cap B$ is the intersection of $A$ and $B$ and $A\cup B$ is the union of $A$ and $B$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
