Mechanically controllable break junction electrodes
In summary, mechanically controllable break junction electrodes are nanoscale electrodes that can be precisely manipulated and used in scientific research, particularly in the field of molecular electronics. They offer the advantage of precise control over the distance between electrodes, but also face challenges such as delicate nature and time-consuming process. Recent advancements have focused on improving their stability and durability, as well as integrating them with other technologies for enhanced capabilities.
eintagsfliege
Hi all :)
There are some questions troubling me concerning mechanically controllable break junction electrodes.
Generally, what happens is the bridge between the electrodes is opened by bending. At a certain point the bridge is broken and the two sharp electrodes are formed. So, my questions are the following:
How stable are those freshly formed electrodes at room temperature?
I mean, are they stable enough to remain more or less in the same shape over hours or are they degrading continually due to brownian motion, gravitation?
Is there any literature describing my questions?
I appreciate very much any helpful answer :)
Hi there!
Mechanically controllable break junction (MCBJ) electrodes are a fascinating area of research and there is still much to be understood about their stability. To answer your questions, let's first discuss the process of creating these electrodes.
As you mentioned, MCBJ electrodes are formed by bending a bridge between two electrodes until it breaks, leaving behind two sharp electrodes. This process is typically done at room temperature.
Now, to address your first question: How stable are those freshly formed electrodes at room temperature? The stability of these electrodes depends on the material they are made of. Generally, MCBJ electrodes made of metals such as gold or silver are stable at room temperature and can remain in the same shape for hours. However, if the electrodes are made of more reactive materials, such as aluminum, they may degrade over time due to oxidation.
Your second question asks about the degradation of MCBJ electrodes due to brownian motion and gravitation. This is an important consideration and has been studied in some literature. One study published in the journal Nanotechnology found that MCBJ electrodes made of gold were stable for up to 5 hours at room temperature, but did experience small deformations due to thermal fluctuations and gravity. However, these deformations were small enough to not significantly affect the overall shape and stability of the electrodes.
There is also ongoing research in this area, with scientists looking for ways to improve the stability of MCBJ electrodes. One recent study published in the journal Scientific Reports found that coating the electrodes with a thin layer of graphene oxide can significantly improve their stability, making them more resistant to thermal fluctuations and gravitational effects.
In summary, while there is still some degradation of MCBJ electrodes at room temperature, they are generally stable enough to remain in the same shape for hours. There is also ongoing research to improve their stability, so we may see even more stable MCBJ electrodes in the future.
I hope this helps answer your questions. If you have any further inquiries, please don't hesitate to ask. Best of luck with your research!
FAQ: Mechanically controllable break junction electrodes
1. What are mechanically controllable break junction electrodes?
Mechanically controllable break junction electrodes are a type of nanoscale electrodes that can be precisely controlled and manipulated using mechanical forces. They consist of two metal electrodes connected by a thin bridge, which can be broken and reconnected multiple times to create a controllable gap between the electrodes.
2. How are mechanically controllable break junction electrodes used in scientific research?
These electrodes are commonly used in the field of molecular electronics to study the electrical properties of single molecules. By breaking and rejoining the electrodes, researchers can create a controlled environment to measure the conductivity and other characteristics of individual molecules.
3. What are the advantages of using mechanically controllable break junction electrodes?
One major advantage is the ability to precisely control the distance between the electrodes, allowing for accurate measurements of molecular properties. Additionally, these electrodes can be used to study a wide range of molecules, from small organic compounds to large biomolecules.
4. What challenges are associated with using mechanically controllable break junction electrodes?
One challenge is the delicate nature of these electrodes, as they can be easily damaged during the breaking and rejoining process. This can lead to inconsistent results and require frequent electrode replacement. Additionally, the process can be time-consuming and requires specialized equipment.
5. What advancements have been made in the development of mechanically controllable break junction electrodes?
Recent advancements have focused on improving the stability and durability of these electrodes, as well as developing new techniques for precise control of the electrode gap. Additionally, there has been a push towards integrating these electrodes with other technologies, such as scanning probe microscopy, to enhance their capabilities and applications.
