Mechanics 1 (M1) - Vertical motion under gravity
In summary, the greatest height reached by the ball is 9.27m and the distance below the window of the point where the balls meet is 0.104m.
Ulti
A girl throws a ball vertically upwards with speed 8ms^-1 from a window which is 6m above horizontal ground.
(a) Find the greatest height above the ground reached by the ball. (COMPLETE)
(b) Find the distance below the window of the point where the balls meet.
http://img505.imageshack.us/img505/6465/55061996xe3.png
Vertical motion under gravity (ignoring air resistance)- Releasing objects
v=gt
v^2=2gh
h=1/2gt^2
Vertical motion under gravity (ignoring air resistance)- Projecting objects
v=u-gt
v^2=u^2-2gh
h=ut-1/2gt^2
Where:
v=final velocity
u=initial velocity
t=time
g=acceleration due to gravity (count as 9.8ms^-2)
h=height from ground(a.k.a. distance)
Well I have done the first part...
(a) 2gh=u^2-v^2
h=(u^2-v^2)/2g
=(8^2-0)/2*9.8
=3.27m
6+3.27=9.27m (FINAL ANSWER)
However for (b) I do not know where to start. I know the answer is 0.104m (checked the answers) but I have no idea how to arrive there, I have simply done scribbles all over the place:
Attempt 1
http://img505.imageshack.us/img505/8835/attempt1kv2.png
Attempt 2 (Using previous info)
http://img508.imageshack.us/img508/9710/attempt2sw1.png
I hope someone can tell me where I am going wrong or give me a few tips on what to do and I should be able to calculate the rest.
P.S. Thanks in advance! I'm not sure if this is the right section as this unit is part of the maths AS course but mechanics is mainly physics so I placed the question here - my apologies if it is in the wrong section.
v=gt
v^2=2gh
h=1/2gt^2
v=u-gt
v^2=u^2-2gh
h=ut-1/2gt^2
Where:
v=final velocity
u=initial velocity
t=time
(a) 2gh=u^2-v^2
h=(u^2-v^2)/2g
=(8^2-0)/2*9.8
=3.27m
Welcome to PF.
The first part looks good.
The second part requires that you develop 2 equations, one for the motion of each ball.
You know that they will meet at the same time.
Thanks for the welcome!
I really can't find the answer though lol.
I will rest my head for tonight and try this problem again tomorrow, thanks for now.
While you are resting think about where the first ball will be and how fast it is going when the second ball is dropped.
Get a good sleep and maybe it will occur to you in a dream.
Hi, I think I might have the solution for your problem.
First of all, I think that the answer s = 0.104m is not really that accurate.. I tried plugging in your answer and it won't meet at that distance below the window..
Anyway, here is my solution, I used g = 9.81ms^-2
First ball,
s = ut + 1/2 at^2
s = 8t - 4.905t^2
For second ball,
Using the same equation,
s = 0 + 4.905( t -1.5 )^2
This is because since the second ball is always ahead of the first ball by 1.5 s.
Now, this equating both equation, and putting in mind that the we let the motion of the first ball that is thrown upwards to be negative and the motion of the second ball downwards to be positive displacement.
s (1) = s (2)
-(8t - 4.905t^2) = 4.905 ( t-1.5 )^2
Expanding the equation,
You will get,
6.715t = 11.036
Hence, t = 1.6435s
Now plugging back to either equation,
Lets say the first equation,
s = -8(1.6435) + 4.905(1.6435)^2
s = 0.101 m
And you will get the same if you put it in equation 2..
So both equation are satisfied..
Even so, if i used g =10 I still will not get 0.104m
Anyway i hope that you are happy with my solution and I hope you understand this..
All the best,
By Victorian91..
Physics rocks..
This question too has been bothering me but I've just managed to sort it out ! Here's my solution.
Stone A:
s=s1m
u=-8ms-1
v=?
a=9.8ms-2
t=t
Stone B:
s=s2m
u=0ms-1
v=?
a=9.8ms-2
t=t-1.5
So from using equations of motion on Stone A:
s=1/2(u+v)t2
=>s1=-8t+1/2(9.8)t2
1=>s1=-8t+4.9t2
And using the eqations of motion on Stone B:
s=1/2(u+v)t2
=>s2=0t+1/2(9.8)(t-1.5)2
=>s2=4.9(t-1.5)2
=>s2=4.9(t2-3t+2.25)
2=>s2=4.9t2-14.7t+11.025
Make the equations equal to each other in order to find the time in which the balls meet:
1=2
=>-8t+4.9t2=4.9t2-14.7t+11.025
=>-8t=-14.7t+11.025
=>6.7t=11.025
=>t=11.025/6.7
=>t=1.645522388
=>t=1.65s
Now substitue t=1.65s into equation, 1:
=>s=-8t+4.9t2
=>s=-8(1.65)+4.9(1.65)2
=>s=0.104m
Although I've managed to do it correctly on paper, I believe I may have made many sign errors on here so watch out ! If you spot what they are feel free to tell me so I can correct it. (:
Also Victoria91, you made a mistake in your calculation of t, it is slightly off, which is why your answer for s is also slightly off.
Related to Mechanics 1 (M1) - Vertical motion under gravity
1. What is vertical motion under gravity?
Vertical motion under gravity refers to the movement of an object in a vertical direction (up or down) due to the force of gravity acting upon it.
2. How is vertical motion under gravity affected by mass and distance?
The mass of an object does not affect its vertical motion under gravity, but the distance it falls does. Objects with different masses will reach the ground at the same time if they are dropped from the same height.
3. What is the acceleration of an object in vertical motion under gravity?
The acceleration of an object in vertical motion under gravity is always equal to the acceleration due to gravity, which is approximately 9.8 meters per second squared (m/s^2) on Earth.
4. How does air resistance affect vertical motion under gravity?
Air resistance can have a significant impact on the vertical motion of an object under gravity. As an object falls, it experiences air resistance which increases as its speed increases. This can cause the object to reach a terminal velocity where the force of air resistance is equal to the force of gravity, resulting in a constant speed.
5. What is the formula for calculating the time of flight for an object in vertical motion under gravity?
The formula for calculating the time of flight for an object in vertical motion under gravity is t = (2v/g), where t is the time of flight, v is the initial velocity, and g is the acceleration due to gravity.
