Mechanics - Castle under siege
  • Thread starter Natasha1
  • Tags
    Mechanics
In summary, the cannonball fired by the defenders just clears the top of the castle wall and takes 4.5 seconds to travel the 200m distance.
Natasha1
494
Need to do this by tomorrow guys just need some help with it. Could anyone help to get me started please :-)
A castle is under siege. Its walls are 40m high, and it stands on level ground. The besiegers have a cannon at ground level 200m away and aim directly towards the castle and an angle of 35 degrees to the horizontal.
Using the standard equation for path, or working from first principles, find the speed of firing for a cannonball to just clear the top of the wall of the castle and find the time taken?
The defenders also have a cannon placed at the top of the walls, and can only fire this horizontally. Their aim is to either hit the opposing cannon, or to hit the members of the opposing army strung out behind for a distance of a further 200m. What range of values of speeds of firing is appropriate for the defenders’ cannonball?
PS: Air resistance is to be ignored in this question
Do you know "the standard equation of path" as mentioned in the question? If you do, then I think this problem can be easily solved.
Is it y = x * tan (alpha) - (g/2u^2) sec^2 (alpha) * x^2
[tex] y = xtan\theta - \frac {gx^2}{2u^2cos^2\theta} [/tex] ?Looks good to me...Don't know why but I can never fully remember that formula...always have to derive it or look it up but any way...
The only variable in there that you don't know is u :smile: ..with this you can then find t.
Have I got this right please... could someone take 5 mins to check all calculations to see if I'm correct, and tell me if I have gone wrong somewhere. Thanks :-)
Right...
Solving forces horizontally:
constant speed of: u.cos alpha
so
x = u.cos alpha.t
200=u.cos 35. t (1)
Solving vertically:
a=-g
Initial velocity: u.sin alpha
y = u.t + 1/2 a.t^2
y = u. sin alpha . t - (1/2) g.t^2
40 = u. sin 35.t - (1/2) (10). t^2 (2)
From (1) we get u = 200 / cos 35.t
replacing in (2) we get:
40 = (200 / cos 35.t) sin 35.t - (1/2) g.t^2
40 = 200.tan 35 - (1/2) g.t^2
(1/2)g.t^2 = 200 tan 35 - 40
5t^2 = 200 tan 35 - 40
t^2 = 40 tan 35 - 8
t = 4.473 seconds
As
u = 200 / cos 35.t
u = 200 / cos 35 * 4.473
u = 54.584 ms-1
I actually found first t then u, is this still ok?
Can see no problems with your working or answer. :smile: Which you find first, v or t, doesn't really matter because both can be expressed in terms of the other and then substitutions made.
The only thing I would say is that you give your final values with accuracy to 3 d.p. given that you use g = 10 in addition to other assumptions this seems a bit odd. I would just say u =55 m/s and t = 4.5 secs
FAQ: Mechanics - Castle under siege
What is the objective of "Mechanics - Castle under siege"?
The objective of "Mechanics - Castle under siege" is to defend your castle from enemy attacks and ultimately conquer their castle as well. This is achieved through strategic planning, resource management, and building and upgrading structures.
How do I build and upgrade structures in the game?
In order to build and upgrade structures, you will need resources such as wood, stone, and gold. These resources can be obtained by completing tasks, trading with other players, or attacking enemy castles. Once you have enough resources, you can click on the "Build" or "Upgrade" button next to the structure you want to improve.
How do I defend my castle from enemy attacks?
To defend your castle, you can build defensive structures such as walls, towers, and traps. You can also train soldiers to defend your castle and assign them to specific areas of your castle. It's important to constantly monitor and upgrade your defenses to stay ahead of enemy attacks.
What are some tips for successful gameplay?
Some tips for successful gameplay include constantly gathering resources, joining alliances with other players, and communicating with your team to coordinate attacks and defenses. It's also important to be strategic with your building and upgrading choices and to constantly monitor your castle's defenses.
Is there a multiplayer aspect to the game?
Yes, "Mechanics - Castle under siege" has a multiplayer aspect where you can join or create alliances with other players. This allows you to work together to conquer other castles and defend against enemy attacks. You can also communicate and trade with alliance members to strengthen your gameplay.
