MHB Mechanics- connected particles
The discussion involves calculating the maximum driving force and acceleration of a car pulling a caravan under specific conditions. The car has a mass of 2000kg, and the caravan weighs 1200kg, with resistances of 20N and 80N respectively. The maximum driving force from the car's engine is 1900N, and the tow-bar can withstand a maximum tension of 680N. The calculations show that the maximum possible driving force before the tow-bar breaks is 1700N, leading to a maximum acceleration of 0.5m/s². The approach taken in the calculations is confirmed to be correct.
Shah 72
MHB
A car of mass 2000kg pulls a caravan of mass 1200kg along a straight horizontal road. The resistance on the car is 20N and the resistance on the caravan is 80N. The max possible driving force from the car's engine is 1900N. The tow-bar will break if the tension exceeds 680N.
a) Find the max possible driving force before the tow-bar breaks.
b) Find the maximum possible acceleration.
Mathematics news on Phys.org
So I did -20-680-80=3200a using F=m×a
a= -0.244m/s^2
Again using f=m×a
F-680-20=2000×-0.244
F=212N
Max force= 1900-212=1688= 1700N correct to 2sf
Max possible acceleration will be a=1700/3200=0.5m/s^2
Is this the correct way of doing this??
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
