MHB Mechanics- connected particles
To find the tension in the lift cable for a crate and lift system, the calculations vary based on the lift's motion. When the lift accelerates upwards at 0.3 m/s², the tension is calculated using T - (weight of lift + weight of crate) = (total mass) * acceleration, resulting in approximately 3300 N. For constant speed, the tension equals the total weight of the lift and crate, which is around 3200 N, as there is no acceleration. When the lift accelerates downwards at 0.3 m/s², the equation reverses, leading to a different tension value. Understanding these dynamics is crucial for accurate calculations in mechanics involving connected particles.
Shah 72
MHB
A crate of mass 20 kg is put into a lift. The mass of the lift is 300kg. Find the tension in the lift cable.
a) when the lift accelerates upwards at 0.3m/s^2
b) when the lift travels at constant speed
c) when the lift accelerates downwards at 0.3m/s^2
For (a) is it T- W-w= ( M+m) a
Where T is tension of the cable, W is the weight of the lift and w is the weight of the mass.
I don't know how to calculate (b) and (c)
Mathematics news on Phys.org
For a I did T-3000-200= 320×0.3
Iam getting 3296N
b) I did T-3000-206= 320×0.3, I get 3302, textbook ans for (b) is 3200 and for (a) its 3300N
scalar equations ... all use the magnitude of acceleration
(a) $T - 320g = 320a$
$a$ is upward
(b) $T - 320g = 0$
no acceleration, why?
(c) $320g - T = 320a$
$a$ is downward
$a$ is upward
(b) $T - 320g = 0$
$a$ is downward
Second case is constant speed so a=0.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
