Mechanics- connected particles
In summary, the problem requires calculation of two accelerations. The first, $a_1$, is determined by the equations$T - f_k = ma_1$$Mg - T = Ma_1$The second acceleration, $a_2$, is only for the smaller mass. After moving that 1m, tension becomes zero when the larger mass hits the ground. The smaller mass continues moving with acceleration $a_2$ until it comes to a stop.
Shah 72
MHB
274
I calculated a=8m/s^2. I don't understand how to calculate the total time.
Mathematics news on Phys.org
same concepts apply to this problem as with the other posted pulley problem ...
Using s= 1/2at^2, 5=1/2×8×t^2
t=1.12s
After this how do I calculate? It's confusing.
The problem requires calculation of two accelerations. The first, $a_1$, is determined by the equations
$T - f_k = ma_1$
$Mg - T = Ma_1$
The second acceleration, $a_2$, is only for the smaller mass …
$-f_k = ma_2$
The small mass moves only 1m with acceleration $a_1$. After moving that 1m, tension becomes zero when the larger mass hits the ground. The smaller mass continues moving with acceleration $a_2$ until it comes to a stop.
$T - f_k = ma_1$
$Mg - T = Ma_1$
$-f_k = ma_2$
$T - f_k = ma_1$
$Mg - T = Ma_1$
$-f_k = ma_2$
So a= 8m/s^2
S= ut +1/2at^2
1=1/2×8×t^2, t=0.5s
I calculated v=4m/s
F=m×a
-5=0.5×a
a=-10m/s^2
I still don't get the ans mentioned in the textbook which is t= 2.5s
correct on the first part …
$a_1= 8 \, m/s^2 \implies t_1 = 0.5 \, s \implies v_f = a_1 t_1 = 4 \, m/s$
$v_f = 4 \, m/s$ becomes $v_0$ for the second part …
$a_2 = -\mu g = -2 \, m/s^2$
$v_f = v_0 + a_2t_2 \implies 0 = 4 - 2t_2 \implies t_2 = 2 \, s$
$t_1+t_2 = 2.5 \, s$
Thank you so so so so so so much!
FAQ: Mechanics- connected particles
What is the definition of connected particles in mechanics?
Connected particles in mechanics refer to two or more particles that are linked together by a physical connection, such as a string, rod, or spring. This connection allows the particles to move together and affects their overall motion.
What is the equation for calculating the acceleration of connected particles?
The equation for calculating the acceleration of connected particles is F = ma, where F is the net force acting on the particles, m is the total mass of the particles, and a is the resulting acceleration.
How does the mass of connected particles affect their motion?
The mass of connected particles affects their motion by determining how much force is required to accelerate them and how they respond to external forces. Heavier particles will require more force to accelerate and will have a slower response to forces compared to lighter particles.
What is the difference between internal and external forces in connected particles?
Internal forces in connected particles are forces that are exerted between the particles themselves, such as tension in a string or compression in a spring. External forces, on the other hand, come from outside the system of connected particles and can include forces like gravity or friction.
How do you calculate the tension in a string connecting two particles?
To calculate the tension in a string connecting two particles, you can use the equation T = mg + ma, where T is the tension, m is the mass of the particles, g is the acceleration due to gravity, and a is the acceleration of the particles. This equation takes into account the weight of the particles as well as any additional forces acting on them.
