MHB Mechanics: Friction - Wheelbarrow Mass 8kg, Coeff. 0.6, Force 50N, Angle 30°
The discussion focuses on the mechanics of a gardener pulling a wheelbarrow with a mass of 8kg and a coefficient of friction of 0.6. The gardener applies a force of 50N at a 30-degree angle, resulting in an acceleration of 1.29 m/s². When the wheelbarrow is loaded with an additional 20kg of soil, the total mass becomes 28kg, increasing the normal force and friction. The horizontal component of the applied force is insufficient to overcome the maximum friction force, leading to a calculated negative acceleration of -3.92 m/s², indicating that the wheelbarrow does not move. This analysis confirms that the applied force is inadequate to initiate movement under the increased load.
Shah 72
MHB
A gardener is pulling a wheelbarrow of mass 8kg from rest along rough horizontal ground. The coefficient of friction between the wheelbarrow and the ground is 0.6. The gardener provides a force of 50N at an angle of 30 degree above the horizontal as shown in the diagram.
a) Find the acceleration of the wheelbarrow
I got the ans for this a = 1.29m/s^2
b) what happens when the wheelbarrow had 20kg of soil in it and the gardener exerts the same force at the same angle?
I don't understand how to solve this.
Mathematics news on Phys.org
mass of the wheelbarrow is now 8+20 = 28 kg
normal force increases $\implies$ friction force will increase
compare the updated friction force to the horizontal component of the applied 50N force
Thank you. So the new contact force =255N and friction is 153N. By using F=m×a, 50cos30-153=28a, I get a=-3.92m/s^2. So since the acceleration is negative the wheel barrow doesn't move. Is this reasoning correct?
There is no acceleration ... the horizontal component of the applied force is not great enough to overcome the maximum force of friction.
Thank you !
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
