Mechanics: Motorcycle propulsion
In summary, the task is to find the time it takes to accelerate a motorcycle from 0 to 100 km/hr, given various parameters such as rider and bike mass, torque, wheel radius, and gear ratios. To solve this problem, a model of the motorcycle and its components must be established, including assumptions if necessary. Once the acceleration equation is derived, modifications to the bike can be made to compare the resulting performance.
jrenman
You must find the time it takes to accelerate (at constant applied torque) a motorcycle from 0 to 100 km/hr,
given:
Rider mass: 75 kg
Bike total mass: 190 kg
Torque at crankshaft of motor: 105 Nm
Front and rear wheel masses (10 kg and 17 kg respectively)
Radius of wheels: 0.25 m (includes tire)
Radius of wheel hubs: 0.075 m
Wheel composed of 4 straight, uniform spokes. 1/3 of the wheel mass is in the hub, 1/3 in the spokes, and 1/3 in the rim (includes tire).
Ratio of transmission primary drive gear to crankshaft gear radii: 2.5. Ratio of rear sprocket to front sprocket radii: 2.5.
Once you find an equation for the acceleration (and therefore the time), compare the increased performance that would result from the following two modifications to the bike:
a) Lowering the non-rotating mass by 5 kg, and increasing the torque by 5 Nm [this is what you would get by changing the exhaust system).
b) Reducing the front and rear wheel masses by 2 kg and 5 kg respectively, and their moments of inertia by 50% each (this is what you would get by changing the wheels).
N_ext = mR_(centre of mass) x a_com + I_com[tex]\alpha[/tex]
I think I am supposed to find the time from 0->100km/hr, then calculate an equation in terms of masses and moments of inertia(?) of wheels and then...
I'm not sure where to start really or what steps to take to get in the right direction.
Any help and advice would be wonderful.
Thanks in advance!
It may help to draw a diagram with the various relevant parts of the motorcycle and environment and how they each relate to each other. For instance, if one part transfer power to another part, then what physical variables (like torque, force, angular speed, speed) and characteristics (like mass, moment of inertia, etc) are involved in that transfer). You may need to make assumptions (remember to explain those in your solution) as to how some of the parts relate to each other if the problem text does not specify the details. You should now be able to analyse how to answer the question in the context of your model, like what equations you have to solve to get the answer.
Regarding your specific question, you do need to establish a model of your bike before you can answer the 0 to 100 km/h question. Then the other two questions require you to change your model and (re-)calculate how that affects the acceleration time.
Related to Mechanics: Motorcycle propulsion
1. How does a motorcycle engine produce power?
A motorcycle engine produces power through a process called internal combustion. This involves igniting a mixture of fuel and air inside the engine, which creates a controlled explosion that pushes pistons and turns a crankshaft. This motion is then transferred to the wheels of the motorcycle, propelling it forward.
2. What are the main components of a motorcycle's propulsion system?
The main components of a motorcycle's propulsion system include the engine, transmission, and drivetrain. The engine is responsible for producing power, while the transmission and drivetrain work together to transfer that power to the wheels.
3. How does a motorcycle's transmission affect its performance?
A motorcycle's transmission is responsible for changing the gear ratio between the engine and the wheels. This allows the motorcycle to efficiently use the power produced by the engine at different speeds. A well-designed transmission can greatly improve a motorcycle's acceleration and top speed.
4. What is the role of the drivetrain in a motorcycle?
The drivetrain of a motorcycle includes the chain, sprockets, and rear wheel. Its main purpose is to transfer power from the transmission to the rear wheel, which ultimately propels the motorcycle forward. The drivetrain also allows the rear wheel to spin at different speeds while the motorcycle is turning or going over uneven terrain.
5. How does engine displacement affect a motorcycle's performance?
Engine displacement refers to the volume of air and fuel that can be drawn into the engine's cylinders. In general, a larger engine displacement means more power can be produced, resulting in better acceleration and higher top speed. However, there are other factors such as weight and design that also play a role in a motorcycle's performance.
  • Mechanics
  • Mechanical Engineering
  • Mechanics
  • Other Physics Topics
15K
  • Mechanics
