Mechanics of materials centroidal question
In summary, the conversation discusses finding the neutral axis, area centroid, and their distance in a beam section. There is a disagreement on whether the area centroid is equal to half or a fourth of the distance from the neutral axis. It is suggested to review the fundamentals and find a proof for the correct answer.
EITintraining
a beam is 12 cm wide and 10 cm long. Find the neutral axis, the area centroid and the distance between them.
Yc=h/2
Yc=10/2=5 cm.
I can't seem to find the area centroid of a rectangle. Any help? Thanks!
Your question isn't clear to me. Do you mean "beam section"? The neutral axis would be a neutral plane, depending on the direction of loading. On the other hand, it seems a very trivial question. What do you think the answer is? If you were answering this in an exam, and had 15 seconds to answer it, what would you say to get a possible mark?
Well I thought that the answer would be the same for the neutral axis as for the area centroid, h/2. But the answer in the back says the area centroid is actually h/4. So the area centroid is half of the distance from the neutral axis?
There is a proof (in my strength of materials book) that, under pure bending, the neutral axis is coincident with the centroidal axis. The circumstance in which this is not the case is when there is a combination of axial load and bending, The book could be wrong, as many authors in this forum will attest. On the other hand, the question could be a clumsy attempt to get you to look hard at the fundamentals. See if you can find that proof, and then go and teach it to an interested friend.
The area centroid of a rectangle is located at the intersection of its diagonals. In this case, the centroid will be located at the center of the rectangle, which is (6 cm, 5 cm). The distance between the centroid and the neutral axis (also known as the neutral axis offset) can be calculated using the formula: h/2, where h is the height of the rectangle. In this case, the distance would be 5 cm. It is important to note that the neutral axis of a rectangle is always located at the centroid of the shape. I hope this helps!
FAQ: Mechanics of materials centroidal question
What is the centroid of a shape in mechanics of materials?
The centroid of a shape in mechanics of materials is the geometric center of the cross-sectional area of the shape. It is the point where the area is evenly distributed on both sides, and is a crucial concept in understanding the distribution of forces in a structure.
2. How is the centroid of a shape calculated in mechanics of materials?
The centroid of a shape can be calculated using the formula: x̄ = (1/A) ∫ x dA, where is the centroid location, A is the area, and x is the distance from the centroid to the axis of interest. This formula can be applied to both 2D and 3D shapes.
3. What is the significance of the centroid in mechanics of materials?
The centroid is an important concept in mechanics of materials as it helps to determine the location of the center of mass, which is essential for analyzing the stability and equilibrium of a structure. It also plays a crucial role in calculating the moment of inertia and shear center of a shape.
4. How does the location of the centroid affect the bending of a beam?
The location of the centroid of a cross-section influences the distribution of stress and strain in a beam under bending. A beam with its centroid located closer to the neutral axis will experience less bending stress compared to a beam with its centroid farther away from the neutral axis.
5. Can the centroid of a shape change when subjected to external forces?
No, the centroid of a shape does not change when subjected to external forces. However, the distribution of the forces and moments may change, which can affect the location and magnitude of the centroid in relation to the axis of interest.
10K
