Mechanics of Materials - Deflection of a rigid bar
In summary, the conversation discusses solving for the deflection, ∂, at the end of a beam with a given stress-strain diagram and a load of 50 kN. The equations used include E = stress/strain, ∂ = PL/AE, F = k∂, and k = AE/L. The attempt at a solution involves finding the elastic modulus, solving for tension in the cable, and creating a compatibility sketch. However, there may be a mistake in the calculations as the resulting deflections seem too high.
ginrummy
http://img.waffleimages.com/5b5524d885644e9f1c76a800c4b0701a0606268a/problem6.jpg
(The image will not work unless it is copied and pasted into the address bar)
I am given this drawing and stress v strain diagram, and am told to find the deflection, ∂, at 4 (the end of the beam), if P = 50 kN.
When solving by geometry:
E = stress/strain
∂ = PL/AE
F = k∂
k = AE/L
Using the stress v strain diagram provided, I solve for the elastic modulus (Young's modulus):
E = (700x10^6 N/m^2)/(.35) = 2x10^9 N/m^2
Take the moment about point A to solve for tension in the cable, T2:
(clockwise is positive) ∑MA= 0= (1.4 m)(-T2 N)+(2.2 m)(50,000 N) => T2= 78,571.43 N
From there, I do a compatibility sketch. Unfortunately I do not have software on my computer to draw up a diagram to post, but it is a right triangle, with the length of the bar as the "height," and ∂4 and ∂2 serving as the bases in a similar triangle relationship.
Therefore:
(∂4/2.2)=(∂2/1.4) leading to ∂4=(2.2/1.4)∂2
Therefore, using the Hooke's Law equation:
T2= k2∂2 => ∂2= T2/k2
k2= AE/L= [(1.25x10^-4 m^2)(2x10^9 N/m^2)]/3m => k2= 83,333.3 N/m
Therefore:
∂2= 0.943 m
∂4= 1.48 m
These deflections seem WAY too high to be correct. I feel confident that I'm using the right process, but there has to be some mistake I'm making somewhere.
the website http://img.waffleimages.com/5b5524d8...a/problem6.jpg
didn't work for me.
Related to Mechanics of Materials - Deflection of a rigid bar
1. What is the definition of deflection in mechanics of materials?
Deflection refers to the bending or deformation of a material under a load or applied force. It is a measure of how much a material moves or changes shape when subjected to external forces.
2. How is deflection calculated for a rigid bar?
The deflection of a rigid bar can be calculated using the equation Δ = PL^3/(3EI), where P is the applied load, L is the length of the bar, E is the modulus of elasticity, and I is the moment of inertia.
3. What factors affect the deflection of a rigid bar?
The deflection of a rigid bar is influenced by the applied load, the material properties such as modulus of elasticity and moment of inertia, and the length and cross-sectional shape of the bar.
4. How does deflection affect the structural integrity of a rigid bar?
Excessive deflection can lead to failure or collapse of a rigid bar, as it indicates that the material is unable to withstand the applied load. Designers must ensure that the deflection of a rigid bar remains within safe limits to maintain its structural integrity.
5. Can deflection be reduced or prevented in a rigid bar?
Deflection in a rigid bar can be reduced by increasing the material's stiffness, decreasing the applied load, or increasing the bar's cross-sectional area. Proper design and material selection can help prevent excessive deflection in a rigid bar.
18K
14K
