Mechanics of Materials - Where's my mistake?
In summary: The total expansion is indeed 0.425 mm.That is at point A!So at point A you should have an expansion of 0.425 mm.However, at point B the part of the bar to the right will be expanded less, by as much as ΔL_AB.Same thing at point C, where the expansion is only ΔL_CD.Finally at point D, the expansion would have to be zero.Connect the dots with lines and you have your movement...graph. :)
  • #36
The signs appear to have been no problem at all and your work is neat!
I give it the ILSe Seal of Approval! :smile:
<h2> What is the purpose of studying Mechanics of Materials?</h2><p>The purpose of studying Mechanics of Materials is to understand how materials behave under different types of loading and how they can be designed to withstand these loads. This knowledge is essential for engineers and scientists working in fields such as civil engineering, mechanical engineering, and materials science.</p><h2> What are the basic concepts of Mechanics of Materials?</h2><p>The basic concepts of Mechanics of Materials include stress, strain, and deformation. Stress is the force per unit area applied to a material, strain is the resulting change in shape or size of the material, and deformation is the displacement of the material due to the applied stress.</p><h2> What are the common types of loading in Mechanics of Materials?</h2><p>The common types of loading in Mechanics of Materials are tension, compression, shear, bending, and torsion. Tension and compression involve forces acting in opposite directions along the length of a material, shear involves forces acting parallel to the surface of a material, bending involves forces causing a material to bend or deflect, and torsion involves twisting forces.</p><h2> What are the main equations used in Mechanics of Materials?</h2><p>The main equations used in Mechanics of Materials are Hooke's Law, which relates stress and strain for elastic materials, and the equations for calculating stress and strain in different types of loading, such as tension, compression, shear, bending, and torsion. These equations allow engineers to design materials and structures that can withstand specific types and amounts of loading.</p><h2> What are some common mistakes made when studying Mechanics of Materials?</h2><p>Some common mistakes made when studying Mechanics of Materials include not fully understanding the basic concepts, such as stress and strain, not using the correct equations for different types of loading, and not considering all the factors that can affect the behavior of a material, such as temperature and material properties. It is important to have a solid understanding of the fundamentals and to carefully consider all the variables in order to avoid mistakes in the analysis and design of materials and structures.</p>
FAQ: Mechanics of Materials - Where's my mistake?
