Mechanics of Solids Cylinders with Lateral Loads
In summary: If nu =1, then Eps_z = 0, and the stress is purely compressive. If nu>1, then there is some shear stress acting on the rod.
Ogmios
Hi,
I have been searching the web for hours now, and I have had some success, but I have not found everything I am looking for.
The best thing I have found was a similar arrangement in Hibbeler’s Mechanics of Materials (hence the name of the thread). This had a short rod of aluminium in a vice being crushed axially (z). This is a very common problem, and finding the equations for this is simple, many of the texts had these, and the result is a uniform change in diameter in both the x and y directions.
However, I am interested in a rod being crushed diametrically (x), that is, loaded laterally. I have found the equations for the stress in the two dimensions that correspond to the circular cross section, x and y. However, I am also interested in what is happening along the length of the rod, in the z direction.
What I have is for a Force (F) applied in the dimension x, the stress in x ig given by,
σx=-6F/πld
where l is the length of the cylinder, or length over which the force is being applied in my actual application (the gauge length for sensing purposes), and d is the diameter of the cylinder. In the y-axis the stress is given by,
σy=2F/πld
That is, there is a compressive load from the crushing in the x direction, which results in an expansion in the perpendicular diameter (y), resulting in an elliptical cross section. Here is a link to an image I found
http://what-when-how.com/wp-content/uploads/2011/07/tmp1914_thumb.jpg
What I want is to know what is happening along the length. There must be some strain in this direction according to Poisson's ratio, but I could be wrong. The journal articles I have come across just assume that this is zero for simplicity. I assume they can do this because the length (l) is significantly greater than the diameter (d), but no justification is given for this. The interesting thing is that in their experimental results compared to their theoretical prediction, there is a slight difference, and I think this can be explained by what is happening in the length direction.
Any input would be greatly appreciated.
Kind Regards,
G
Is thix crushing between two flat plates, or just how is this load applied to the two siddes of the cylinder? Are you looking for a theory of elasticity solution here?
Hi,
For my application it is a cylinder being crushed between two flat plates. However, it turns out that this is used a lot in geology and other fields, and is referred to as a diametral tensile test (DTT). They can use curved surface, which have a diameter greater than the diameter of the sample being crushed. This is only to help centre the sample. The same test is used on tablets (pills) for "hardness" measurements, and this is between two flat surfaces.
Here is a better image I found when searching for DTT,
http://www.biomedical-engineering-online.com/content/10/1/44/figure/F2
The important thing is that relative to the circumference this is a point load, and is only a distributed load along the length of the cylinder.
What I would like in the first instance is to know if I am right or wrong. That is, is there some strain induced along the length of the cylinder (the thickness as it is referred to in DTT). Then if there is stain induced, how can I determine this; so I guess I am a looking for a theory of elastic solution...
Kind Regards,
G
It has been too long for me to recall the definitions at this point, but you need to look up the terms plane stress and plane strain to see which one of these applies in your case. If the cylinder is infinitely long, one of them will apply, and if it is infinitely short the other will apply, in each case reducing the problem to a 2-D field problem. Get a theory of elasticity book and do some digging.
Ogmios: If we assume the rod is free to slip longitudinally, then for the portion of the rod in the vice/vise, eps_z = -(nu/E)(sigma_x + sigma_y), where eps_z = strain (epsilon) in the z direction, nu = Poisson's ratio, and E = tensile modulus of elasticity.
FAQ: Mechanics of Solids Cylinders with Lateral Loads
What is the definition of a cylinder in mechanics of solids?
In mechanics of solids, a cylinder is a three-dimensional solid object that has two parallel circular bases connected by a curved surface. It can also be thought of as a circular prism.
How do lateral loads affect the behavior of cylinders in mechanics of solids?
Lateral loads, or forces applied perpendicular to the axis of the cylinder, can cause bending and deformation in a cylinder. This can result in stress and strain on the material, potentially leading to failure.
What are some common types of lateral loads that can act on cylinders?
Some common types of lateral loads include wind, seismic forces, and pressure from fluids such as water or gas. These loads can be static or dynamic, and their magnitude and direction can vary.
How do engineers determine the strength and stability of cylinders under lateral loads?
Engineers use various methods, such as stress and strain analysis, experimental testing, and computer simulations, to determine the strength and stability of cylinders under lateral loads. Material properties, geometry, and loading conditions are all taken into consideration.
What are some real-world applications of understanding the mechanics of solids for cylinders with lateral loads?
Understanding the mechanics of solids for cylinders with lateral loads is crucial in the design and construction of structures such as bridges, buildings, and pipelines. It also plays a role in the development of machinery and equipment that use cylindrical components, such as engines and hydraulic systems.
