Mechanics - Particle Sliding down a sphere
In summary, to find the point at which a particle placed at the top of a smooth sphere will slide off, assuming the only force acting on it is gravity, we can use the equation Fn = mg cosθ to calculate the angle of the surface at which the normal force equals the gravitational force. Then, using basic trigonometry, we can find the coordinates of the point where the particle will separate from the sphere.
Doogle
Say I had a smooth sphere of radius r, and I placed a particle at the top and it started sliding down the sphere. At which point (lets say the angle to the horizontal with respect to the origin, taking the center of the sphere to be the origin) does the particle separate with (slide off of) the sphere? Assuming that the only force on the particle is the force due to gravity.
This is not a homework problem, but I'm just curious. Can anyone give me a complete solution? I'm more interested in seeing how it would be done than doing it myself!
Cheers in advance.
Oh I've just seen the same question here https://www.physicsforums.com/showthread.php?t=269635 - reply there instead. Okay don't, that post is a bit old. And they seem to think it's been posted before that even, but I can't find it. Anyone give me a link? Or just a solution? :D
Assuming that the only force acting on the particle is gravity, the point at which it separates from the sphere is when the normal force of the surface of the sphere equals the gravitational force. The angle of the normal force depends on the radius and the angle of the surface, so we can calculate the angle by solving for the angle θ in the following equation: Fn = mg cosθWhere Fn is the normal force, m is the mass of the particle, g is the acceleration due to gravity, and θ is the angle of the surface. So, we can solve for the angle θ by rearranging the equation to get θ = cos-1(mg/Fn).Once we have the angle, we can then calculate the point at which the particle will separate from the sphere by finding the coordinates of the point using basic trigonometry. The x-coordinate of the point is simply rcosθ and the y-coordinate is rsinθ. Hope this helps!
FAQ: Mechanics - Particle Sliding down a sphere
What is the equation for the acceleration of a particle sliding down a sphere?
The equation for the acceleration of a particle sliding down a sphere is a = gsinθ, where g is the acceleration due to gravity and θ is the angle between the tangent to the sphere at the point of contact and the vertical downward direction.
How does the mass of the particle affect its acceleration down the sphere?
The mass of the particle does not affect its acceleration down the sphere. This is because the acceleration depends only on the force of gravity and the angle of the slope, not the mass of the object.
What is the relationship between the speed of the particle and the radius of the sphere?
The speed of the particle is directly proportional to the radius of the sphere. This means that as the radius of the sphere increases, the speed of the particle also increases.
How does the angle of the slope affect the motion of the particle down the sphere?
The angle of the slope affects the motion of the particle down the sphere by changing the acceleration and therefore the speed of the particle. A steeper slope will result in a higher acceleration and faster speed, while a shallower slope will result in a lower acceleration and slower speed.
Can a particle slide down a sphere without any friction?
No, a particle cannot slide down a sphere without any friction. Without friction, the particle would not be able to grip onto the surface of the sphere and would simply roll or fall off. Friction is necessary for the particle to maintain contact with the sphere and continue sliding down.
