Mechanics - Work-Energy Principle Question
In summary, the conversation is discussing a problem involving a car moving with a constant engine rate on a horizontal road, with no resistance to motion initially. The time taken for the car to reach a certain speed is calculated. The conversation then introduces a constant resistance to motion and the work done against it is found, with the magnitude of the resistance being the only unknown. The conversation then moves onto a hill with the same conditions as before, and the time taken for the car to travel a certain distance is calculated. There is some confusion about how to calculate the work done by the resistive force and the net work done on the car, as well as the assumption of constant acceleration.
AntSC
65
a) A car of mass 1050kg moves along a straight horizontal road with its engine working at a constant rate of 25kW. Its speed at a point A on the road is 12ms-1. Assuming that there is no resistance to motion, calculate the time taken for the car to travel from A until it reaches a speed of 20ms-1.
b) Assume now that there is a constant resistance to motion and that the car's engine continues to work at 25kW. It takes 10.7s for the car's speed to increase from 12ms-1 to 20ms-1. During this time the car travels 179m. Calculate the work done against resistance and hence find the magnitude of the resistance.
c) Later the car moves up a straight hill, inclined at 2° to the horizontal. The engine works at 25kW as before, and there is a constant resistance of the same magnitude as before. The car travels a distance of 393m while its speed increases from 12ms-1 to 20ms-1. Calculate the time taken by the car to travel this distance.
I'm lost at part b). I don't know what i am missing with my understanding.
a)
Given that gravitational force is conservative, the work-energy principle can be used.
[tex]P=\frac{E}{t}=\frac{m\left ( v^{2}-u^{2} \right )}{2t}[/tex]
[tex]t=\frac{m\left ( v^{2}-u^{2} \right )}{2P}[/tex]
[tex]t=\frac{1050\left ( 20^{2}-12^{2} \right )}{2\times 25000}[/tex]
[tex]t=5.376s[/tex]
This answer is confirmed correct
b)
[itex]P=Fv[/itex] so [itex]F=\frac{P}{v}[/itex]. [itex]F=ma[/itex] so with a resistive force
[tex]\frac{P}{v}-R=ma[/tex]
Given that work done [itex]W=Fd[/itex] and the net force in the system is now [itex]\frac{P}{v}-R[/itex] then
[tex]W=\left ( \frac{P}{v}-R \right )d[/tex]
So we need the magnitude of [itex]R[/itex] before we can find work done. To find [itex]R[/itex] we need to know the acceleration.
[tex]a=\frac{v-u}{t}[/tex]
[tex]a=\frac{20-12}{10.7}[/tex]
[tex]a=0.748ms^{-2}[/tex]
Now can find [itex]R[/itex]
[tex]R=\frac{P}{v}-ma[/tex]
[tex]R=\frac{25000}{12}-1050\left ( 0.748 \right )[/tex]
[tex]R=1297.9N[/tex]
This is incorrect. Don't know what I'm missing here. Any help would be great. Cheers
a)
[tex]t=5.376s[/tex]
b)
There is no need to assume that acceleration is constant .
How else can i find [itex]R[/itex] without knowing the acceleration? And wouldn't the acceleration be constant given that the resistive force is constant?
It may be constant, but you're making a assumption about that.
The resistive force is constant, but is the NET force constant?
How much work is done by the resistive force?
What is the net work done on the car?
If the engine continues to work at a constant rate then won't the force generated by the engine also be constant? Therefore the net force is constant.
I don't see how i can find the work done by the resistive force because i can't use the work-energy principle as frictional forces are not conservative.
You can determine the Net work done on he system.
Then, you can set up an equation with the resistive force being the only unknown.
How do i find the net work done if i don't know the net force? I can't used work-energy principle as friction is not conservative.
If i just use [itex]F=\frac{P}{v}[/itex] then aren't i assuming [itex]v[/itex] is constant? Clearly it's not as it's increasing over the distance.
Definitely not getting this :(
Hey Ant, I think you are going about this with a bit of calculus pretty easily. Considering you have a constant resisting force and your engine is providing a constant power, I think it is safe to say that you WILL have a constant acceleration. So, remember that the derivative of your work and energy equation with respect to time will give you your power equation.
So, if you set it up,
1/2mv^2 + ∑W = 1/2mv^2
So, the two forces doing work on your object are the force coming from the engine which is working WITH the direction of motion, and the resisting force which is working against it (that means watch your signs). Both of those are unknowns, and after you set that up, take the time derivative of the entire equation and you will be able to work with values that you already know. Remember the chain rule when you take the derivative of the kinetic energy, so that your acceleration pops up.
After that, I would consider working backwards from that point keeping in mind that:
P = W/t (when the power is constant, which is looks like it is)
and
W = F*d
I hope that helped!
The Work-Energy theorem does not require the forces to be conservative.
The engine power is constant, so it's easy to find the work it does in 10.7 seconds.
You can calculate the change in Kinetic Energy.
The difference must be equal to the work done by the resistive force, R.
You also know the distance traveled during the 10.7 seconds.
I thought W-E theorum does require conservative forces. Better check that out again.
For the work done by the engine:
[tex]W_{E}=Fd=\frac{P}{v}d=\frac{25000}{12}\cdot 179=372916J[/tex]
So the net work done:
[tex]W_{N}=\frac{1}{2}m\left ( v^{2}-u^{2} \right )=\frac{1050}{2}\left ( 20^{2}-12^{2} \right )=134400J[/tex]
Work done by resistance:
[tex]W_{R}=W_{N}-W_{E}=372916-134400=238516J[/tex]
Magnitude of resistive force:
[tex]F=\frac{W_{R}}{d}=\frac{238516}{179}=1332N[/tex]
This isn't right, comparing with the answers.
That first formula is incorrect. The force in not constant so you cannot calculate the work done as
W=F*d.
But you don't need to go through this. You know the power and the time. What is the definition of power?
And you don't need conservative forces to apply work-energy theorem. It works for friction forces too.
Or engine forces, as here.
The conservation of energy requires conservative forces.
W=F*d.
Ok so for the energy burn from the engine we have
[tex]W_{E}=Pt=25000\times 10.7=267500J[/tex]
And for the net energy burn of the system we have
The difference is the work done by the resistive force
[tex]W_{R}=267500-134400=133100[/tex]
So
[tex]F_{R}d=133100\; \Rightarrow \; F_{R}=\frac{133100}{179}=744N[/tex]
This looks OK.
Work Energy Principle
Hi Ant.
This problem works out fine. Many people’s problem is that they think analysing acceleration because they assume F=ma is relevant. It is not relevant. WE principle is all about energies at certain times or positions (distances/heights). And that is it.
Don’t get involved in what is happening between these energy ‘points’. No assumptions should be made that the access are linear or anything else. This is all about velocity changes, distance changes (against resistive forces) and/or height changes. Energy sources balanced against energy sinks if you will. In this case gravity is not the energy source. The engine is. And it provides energy at a rate of 25000J/s. power x time = energy supplied.
Energy sinks are increase in KE, increase in GPE and work done against resistive forces over particular distances. That’s all. Forget conservative arguments, red herring.
Happy to discuss
Related to Mechanics - Work-Energy Principle Question
1. What is the work-energy principle?
The work-energy principle states that the work done on an object is equal to the change in its kinetic energy. In other words, when a force is exerted on an object, it either speeds up or slows down, and the amount of work done is equal to the change in the object's kinetic energy.
2. How is work calculated in the work-energy principle?
Work is calculated by multiplying the force applied to an object by the distance the object moves in the direction of the force. This can be expressed as W = Fd, where W is work, F is force, and d is distance.
3. What is the relationship between work and energy in the work-energy principle?
Work and energy are directly related in the work-energy principle. The work done on an object results in a change in the object's energy, specifically its kinetic energy. This principle can also be used to calculate the amount of work needed to change an object's energy.
4. Can the work-energy principle be applied to all types of energy?
Yes, the work-energy principle is a fundamental concept in physics and can be applied to all types of energy, including kinetic, potential, and thermal energy. It can also be applied to systems with multiple objects and various types of forces.
5. How is the work-energy principle used in real-world applications?
The work-energy principle is used in many real-world applications, such as calculating the energy needed to launch a rocket or determining the amount of work required to lift an object to a certain height. It is also used in designing machines and structures to ensure they can efficiently transfer and use energy.
