Mechanism for generating the energy in supernova
In summary, a type II supernova is the result of the core of a star collapsing, turning into a neutron star, and then releasing energy as particles are brought to an abrupt stop.
mrcotton
120
In a type II supernova If I remember correctly the core of the star collapses and turns to a neutron star. The envelope then will accelerate towards the core. The energy then come from the release of the kinetic energy of the infalling particles as they are brought to an abrupt stop by the incredibly dense surface of the neutron core. Can anyone shed any light on this idea for me please.
Astronomy news on Phys.org
The pressure required to compress matter to 'neutronium' is much greated than exists even in giagantic stars. According to theory, when a star accumulates enough iron in its core to surpass the Chandrasekhar limit, the core collapses triggering a supernova eruption [hence the term core collapse supernova]. The extra pressure furnished by the collapse supplies the force necessary to create a neutron star. The great majority of neutron stars are at or below the Chandrasekhar limit of 1.4 solar masses.
Is there a paper or something somewhere that explains step by step what happens during the collapse? Something with a little more detail than wikipedia?
Awesome, thanks Chronos.
Yes an awesome document thank you Chronos, and thanks to everyone else for the responses. It is the bounce I was particularly interested in. It was something I remembered from a lecture on my degree course. It was the idea that gravitational energy of the in falling matter as struck it the surface of neutrons at nuclear densities. I am developing some resources for my colleagues for use in secondary schools and sixth form colleges. It is such an interesting topic to the students and there is very little information to feed the thirst they have for knowledge about the physics of the situation.
It is this statement on page 3 of the reference above from Chronos that I would really like help interpreting if possible
“The abrupt halt of the collapse of the inner core and its rebound generates a shock wave as the core’s outer half continues to crash down. Once it was thought that this bounce might actually be the origin of the supernova’s energy (3,4), that the outward velocity of the bounce would grow as it moved into the outer layers of the core and
eject the rest of the star with high velocity. Now it is known that this does not occur. Instead, the shock wave stalls due to photodisintegration and copious neutrino losses. A few milliseconds after the bounce, all positive velocities are gone from the star and the dense, hot neutron-rich core (commonly called a proto-neutron star) is accreting
mass at a few tenths of a solar mass per second.”
Many questions remain about the exact details of the explosive phase. This paper may offer some insight: Explosion Mechanisms of Core-Collapse Supernovae, http://arxiv.org/abs/1206.2503
Wow, thanks again Chronos. Those were awesome papers.
I have an obsession with neutron stars due to my unnatural curiosity about the apparent mass gap between neutron stars and stellar mass black holes. I blame it all on Farr, et al: The Mass Distribution of Stellar-Mass Black Holes, http://arxiv.org/abs/1011.1459.
You've already had your answers, so I'll just correct one minor point: you are talking about "core collapse" supernovae, which are not quite the same thing as type II supernovae. A simpler way to think of it is that all supernovae are core collapse except type Ia, which are thermonuclear explosions.
You might think that if we have a type I and a type II, and we have thermonuclear and core collapses, we'd just associate the two, but astronomy never makes that much sense! In astronomy, it is customary to use specific observable features when classifying, and figure out the physics later, so you invariably end up with classifications that don't fit the physics very well (think "planetary nebula", etc.). In the case of supernovae, type I just means that it is absent of hydrogen lines, and type II means it does have hydrogen lines. Since core collapse can occur in helium stars, you can have type I that are core collapse (and there is a zoo of other possibilities as well). Type Ia is also classified based on observations, but the physics works out that this is the type that is not a core collapse (I don't know of any others, but there may be all kinds of fundamentally different kinds of physics going on).
Related to Mechanism for generating the energy in supernova
1. What is the mechanism for generating energy in a supernova?
The primary mechanism for generating energy in a supernova is nuclear fusion, specifically the fusion of lighter elements into heavier ones. This process releases a tremendous amount of energy, which is what causes the explosion.
2. How does nuclear fusion occur in a supernova?
In a supernova, the core of the star collapses under its own gravity, causing the temperature and pressure to increase dramatically. This triggers nuclear fusion reactions, which release energy and create even more heat and pressure. This cycle continues until the star explodes.
3. Are there other sources of energy in a supernova besides nuclear fusion?
Yes, there are other sources of energy in a supernova. For example, the gravitational potential energy of the collapsing core is also converted into heat and radiation. Additionally, the violent shock waves created during the explosion also contribute to the overall energy output.
4. How does the energy from a supernova spread out into the surrounding space?
The energy from a supernova is initially released in the form of intense radiation and shock waves. These travel outwards from the explosion, heating and accelerating the surrounding gas and dust. This causes the supernova remnant to expand and spread out, eventually dissipating into the interstellar medium.
5. Can the energy from a supernova be harnessed for human use?
No, the energy from a supernova is far too powerful and uncontrollable for us to harness for human use. The sheer force of a supernova explosion would be catastrophic for any nearby planets or civilizations. However, the elements created in the explosion can eventually be incorporated into new stars and planets, which can in turn sustain life and potentially be used as sources of energy.
  • Astronomy and Astrophysics
