Mechanism of high-temp. superconductors
In summary, high-temperature superconductors exhibit superconductivity at significantly higher temperatures compared to traditional superconductors and are believed to involve the interaction between electrons and the lattice structure of the material. The main challenges in understanding their mechanism include the complexity of the materials and the lack of a unified theory. These superconductors have been used in practical applications, but further research is needed to improve their performance. High pressures can also increase their critical temperature and enhance their superconducting properties.
raldenorsful
My prof. asked: "What is the mechanism that causes certain materials to exhibit superconductivity at temperatures much higher than around 25 kelvin?"
then until now it remain a question to me?.. so anyone have an idea? thank you.
This is still an open question, so why should your prof ask if he ignores the answer? The best answer is "not BCS".
Related to Mechanism of high-temp. superconductors
1. What is the mechanism behind high-temperature superconductors?
The exact mechanism behind high-temperature superconductors is still not fully understood. However, it is believed that it involves the interaction between electrons and the lattice structure of the material, leading to the formation of Cooper pairs which allow for the flow of electricity with zero resistance.
2. How do high-temperature superconductors differ from traditional superconductors?
High-temperature superconductors have a significantly higher critical temperature (the temperature at which they exhibit superconductivity) compared to traditional superconductors. Traditional superconductors require extremely low temperatures close to absolute zero, while high-temperature superconductors can exhibit superconductivity at temperatures above 77K (-196°C).
3. What are the main challenges in understanding the mechanism of high-temperature superconductors?
The complexity of the materials and the lack of a unified theory are the main challenges in understanding the mechanism of high-temperature superconductors. These materials have complex crystal structures and involve various types of interactions between electrons and the lattice, making it difficult to pinpoint a single mechanism. Additionally, there is currently no comprehensive theory that can explain the behavior of all high-temperature superconductors.
4. Can high-temperature superconductors be used in practical applications?
Yes, high-temperature superconductors have already been used in various practical applications such as MRI machines, particle accelerators, and power transmission cables. However, further research is needed to improve their performance and make them more cost-effective for widespread use.
5. How does pressure affect the superconducting properties of high-temperature superconductors?
High pressures can significantly increase the critical temperature of high-temperature superconductors, leading to even higher superconducting properties. This is because pressure can affect the lattice structure of the material, influencing the interactions between electrons and the lattice and potentially stabilizing the superconducting phase at higher temperatures.
  • Atomic and Condensed Matter
  • Materials and Chemical Engineering
  • Quantum Physics
  • Mechanical Engineering
