riverdinero
- 3
- TL;DR Summary
- Trying to find a way to engage a lock normally operated on by the human hand with some sort of mechanical/electrical solution
Hello,
I hope this is the right place to post about this.
I live in a multi-unit condo, and I have a window that I am trying to lock and unlock from the outside. The window is from the kitchen and looks out onto a public-ish breezeway where I can access easily. I know this might seem a little bit eccentric, but I am constantly passing groceries and packages through this window, and would like to be able to lock and unlock it from the outside, almost like a door. Currently, it only locks on the inside using a latch. Otherwise, the "front door" of the apartment is through in a long hallway, and then through a more cumbersome entryway and series of doors which are difficult to get through when I'm carrying things. If my spouse is home, it's easy to pass things through the window, but I would like a solution to this which let's me unlock the window by myself.
I've attached a couple of annotated photos of the lock mechanism; please let me know if you need to see anything else.
I imagine I can solve this problem by the following, but need help fleshing out the details:
If it makes it simpler, I'm not trying to solve per se for re-locking the window after it's been opened. Also, once the lock is engaged, I can slide the window open, so I don't need a mechanism to 1) disengage the lock and then 2) also provide a sliding force to open the window. I can do the slide by myself from the outside.
To summarize, I believe the main problem I'm trying to solve for is the mechanism that can engage the lock from the inside and mimic the human hand. I do believe it has to be electrically powered, and that there needs to be some sort of switch on the outside (whether a physical switch or using some app on my phone) in order to engage the claw and undo the lock.
I understand I might create a security tradeoff here by doing this, but I don't have anything irreplaceable or of great value inside the apartment, and the convenience of being able to pass things through the window would be pretty helpful for me.
- Place some sort of electric-powered "claw" over the latch on the inside of the window, since it requires a pretty dexterous motion to disengage the lock. I am at a loss for exactly what this mechanism would look like. It would need to simulate the human hand's motion pulling down and to the side to undo the lock.
- Thread a power switch or button through crack between the window and the wall (the window can close and seal completely over a iphone charger wire, and possibly an even bigger electrical wire), that I can use to engage the "claw" mechanism.
- For security, thread the wire with the switch or button used to engage the claw into some sort of lockbox that I can unlock to access the switch.
