Meissner effect and levitation
In summary, the Meissner effect in superconductors is caused by the induction of a current when the superconductor is placed in a magnetic field, which creates an opposite magnetic field that repels the original field and leads to levitation. This effect is not related to the cancellation of the internal magnetic field in the superconductor, but rather the creation of a new magnetic field. Superconductors are effectively diamagnetic, meaning they have a repulsive response to magnetic fields. The term "diamagnetic" refers to the effect, not the cause, and does not fully describe the underlying mechanism in superconductors.
kelvin490
In a field less than critical field, decreasing the temperature below the critical temperature will eliminate the magnetic field inside a superconductor and increase the magnetic field around it. (Meissner effect). But does it related to levitation effect of magnet on a superconductor? What makes it float in air?
Lowering a superconductor into a magnet's field causes a current to be induced into the superconductor (through induction). That current creates its own magnetic field opposite to the other field, which then repel each other. That's why it floats.
If you go above critical temp, the resistance quickly shuts down the current and the magnetic field along with it. So, no more floating.
Likes kelvin490
Does it related to the cancellation of magnetic field inside the superconductor? Is that the induced magnetic field cancels the the magnetic field inside superconductor so that there is no magnetic field inside (Meissner effect)?
No. It simply has to do with the fact that the superconductor is no longer a superconductor when it's above critical temperature. It thus has normal resistance, which turns the current into plain heat in a blink of an eye.
Likes kelvin490
In a textbook the effect is explained this way: "The diamagnetic nature of a superconductor has some interesting mechanical consequences. A paramagnetic or ferromagnetic material is attracted by a permanent magnet because the magnetic dipoles in the material align with the nonuniform magnetic field of the permanent magnet. For a diamagnetic material the magnetization is in the opposite sense, and a diamagnetic material is repelled by a permanent magnet." (University physics).
I wonder why it mentions diamagnetism? A diamagnetic material is slightly repelled by magnet but the mechanism is different from the effect of the Faraday's law of induction. Is the levitation due to diamagnetism?
Diamagnetism is not a description of a cause, but of an effect (which can have several causes). A superconductor in the presence of a magnetic field builds up a field that is opposite to the original field. Thus, it is diamagnetic. Other materials are diamagnetic through totally different mechanisms.
No offense, but I find it kinda weird how your questions continuously search for "some other reason".
Actually the way you explained it is just what I thought about the superconductivity but I get confused when I read more. Since for type 1 superconductor the magnetic field becomes zero inside the superconductor when it cools below critical temperature, I wonder whether we can understand it as a cancel out effect of magnetic field.
A superconductor is effectively diamagnetic. The reason why this is important is that it allows for the magnet to "float" on its own field in a stable configuration. If you try levitate one magnet by placing it on top of another magnet with same polarity you will (obviously) find that they repel each other, but you will also find that it is impossible to find a position where this configuration is stable, the magnet will never float but will want to move to one side etc. In can in fact be shown that it impossible to find a stable configuration (Earnshaw's theorem) unless you have a diamagnet (as opposed to ferro- or paramagnetism). This is why the diamagnetism is important.
Likes kelvin490
That makes it sound as if it isn't really diamagnetic. Superconductors are diamagnets, by the very definition of the term diamagnetic.
I mean, yes, the internal magnetic field is zero because the induced current, which runs mostly on the surface of the superconductor, creates an internal magnetic field that exactly cancels the external field.
But, that is unrelated to the levitation effect. If a superconductor could be superconducting while having its current go through the whole thing (and thus have an internal magnetic field), it would still levitate/be diamagnetic.
Likes kelvin490
I guess that depends on how you see it. I just meant that superconducting materials are not intrinsically diamagnetic in the same way as some elements (say oxygen) and compounds are diamagnetic; the underlying mechanism is quite different. .
Likes kelvin490
Of course the underlying mechanisms are different, but "diamagnetic" refers to the effect ("dia" = opposite) not the cause.
Likes kelvin490
I think I am clear about what leads to the repulsion and the word "diamagnetic" in that textbook just means the effects and says nothing about the intrinsic mechanism.
I have another question as rumborak mention the induced current creates an internal magnetic field that exactly cancels the external field. If the superconductor behave like this it is actually a very strong electromagnet and it also has its north and south pole. Why it can be levitated so stably while a permanent magnet cannot?
The simple answer is, the superconductor's magnetic field is dynamic, and thus counteracts fluctuations. A regular magnet has a static field.
Likes kelvin490
I don't think that is a good way to think about it. A superconductor expels magnetic fields; if you draw the the field lines you will see that they "bend" around the superconductor and never enters it (if we for the moment neglect he penetration depth, which is usually very small). If the superconductor was behaving like a electromagnet it would also have its own field lines. The permanent magnet is floating on it own field, not on top of a field from superconductor.
Hence, the reason why you can get a stable configuration has to do with the fact that this "expulsion" can create a potential minimum, something that is only possible with diamagnetism,. .
Likes kelvin490
It seems that the expels of magnetic flux is a different mechanism then the use induced current to explain the repulsion. But it also seems this repulsion of field lines is not used in explaining other aspects of magnetism. Are there any ways to formulate it mathematically and also use it to explain, say, repulsion between like poles and opposite poles?
Nah, I think "repulsion" vs "cancellation" are just two different ways of looking at the same thing.
Field lines from like poles repel each other is a visual way to describe the repulsion in case of magnets, but in magnets there are field lines inside them. It is different from superconductor which doesn't have field lines inside. I wonder whether we can say there is a repulsion between superconductor and magnet just because we see field lines are bend around. And it seems we need a mathematical way to describe the force between them.
You're not helping yourself in your understanding by treating superconductors as completely new entities that need a new "language" of description. The outside magnetic field *does* penetrate the superconductor, something called the http://en.wikipedia.org/wiki/London_penetration_depth .It is also this surface area in which the currents run that create the canceling magnetic field.
http://en.wikipedia.org/wiki/Maxwell's_equations
Likes kelvin490
I need to clarify what I said previously. The repulsion of lines is a way to describe the repulsion, instead of explain the phenomenon, in situations of both superconductor and magnets. There are always some mechanism behind and the repulsion of field lines is just a result of it. That's why I don't feel comfortable to explain these things in terms of field lines, especially there is no field lines inside superconductor but have field lines in normal magnets. In fact what you said about the induced current previously is already good enough for me to understand the phenomenon, thanks for that.
Related to Meissner effect and levitation
1. What is the Meissner effect?
The Meissner effect is a phenomenon in which a superconductor expels all magnetic fields from its interior when it is cooled below a certain critical temperature. This results in a complete loss of resistance to electrical current and perfect diamagnetism, meaning the material will repel any external magnetic field.
2. How does the Meissner effect cause levitation?
When a superconductor is placed in a magnetic field, the magnetic field lines are repelled from the interior of the superconductor due to the Meissner effect. This creates a strong opposing force that can lift the superconductor off the ground and allow it to levitate in a stable position.
3. What are the applications of the Meissner effect and levitation?
The Meissner effect and levitation have several practical applications, including in magnetic levitation trains, magnetic bearings for high-speed rotating machinery, and magnetic resonance imaging (MRI) technology in medicine. They are also being researched for potential use in energy storage and transportation systems.
4. Can the Meissner effect and levitation occur at any temperature?
No, the Meissner effect and levitation only occur at very low temperatures, typically below the boiling point of liquid nitrogen (-196°C). This is because superconductivity, which is necessary for the Meissner effect and levitation, only occurs at very low temperatures.
5. Can the Meissner effect and levitation be explained by classical physics?
No, the Meissner effect and levitation are phenomena that can only be explained by quantum mechanics. Classical physics cannot fully explain the behavior of superconductors at such low temperatures, where their electrons behave collectively and exhibit quantum effects.
  • Other Physics Topics
  • Atomic and Condensed Matter
  • Quantum Physics
  • General Discussion
