Mellin transform of Dirac delta function ##\delta(t-a)##
happyparticle
##F(s)= \int_0^{\infty} \delta (t-a)e^{-st} dt##
##f(t) = \frac{1}{2 \pi i} \int_{\gamma - i \omega}^{\gamma +i \omega} F(s) e^{st} ds##
Hi,
I found Laplace transform of this Dirac delta function which is ##F(s) = e^{-st}## since ##\int_{\infty}^{-\infty} f(t) \delta (t-a) dt = f(a)##
and that ##\delta(x) = 0## if ##x \neq 0##
Then the Mellin transform
##f(t) = \frac{1}{2 \pi i} \int_{\gamma - i \omega}^{\gamma +i \omega} e^{-sa} e^{st} ds##
Since there's no singularity I can't use the residue theorem, so I'm not sure what else can I use.
I made a mistake, if someone can edit the post I would say the inverse Mellin transform.
You use e but wiki uses x as
The Mellin transform of a function f is
{\displaystyle \left\{{\mathcal {M}}f\right\}(s)=\varphi (s)=\int _{0}^{\infty }x^{s-1}f(x)\,dx.}
Are they equivalent?
Let ##f(x)=\delta(x-a)## a>0
\{Mf\}(s)= a^{s-1}
\{M^{-1}\phi\}(x)= \frac{1}{2\pi i a}\int_{c-i\infty}^{c+i\infty} t^{-s} ds
where t=x/a. It should be ##\delta(x-a)##.
I observe expression of delta(x) in Fourier transform\delta(x)=\frac{1}{2\pi i} \int_{-i\infty}^{i\infty}e^{px} dp
is useful for the proof.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
