Meniscus formation in a beaker
Expert summarizerIn summary, the conversation discusses the concept of the Laplace force, which is a force that arises from the difference in surface tension between the liquid-gas interface and the liquid-solid interface. This force can be calculated using the principle of virtual work and thermodynamic ideas about free energy. In the case of a partially submerged plate, the Laplace force has a vertical component per unit length of ##\gamma_{LV}##, resulting in a downward force of ##\gamma_{LV}\cos{\theta}##. In a beaker, the Laplace force arises from the curvature of the liquid surface at the edges of the beaker, creating a pressure difference and resulting in a force on the beaker.
etotheipi
I will refer to this paper for some relevant bits of theory.
They write that the component of the force between the solid and liquid parallel to the solid-liquid interface, which appears near the contact line (in the dotted region), is ##\gamma_{SV} + \gamma_{LV} - \gamma_{SL}##, which by Young's law also equals ##\gamma_{LV}(1+\cos{\theta})##.
Using the principle of virtual work and some thermodynamic ideas about free energy, we can show that the total force by the whole fluid on the solid parallel to the solid, per unit length of the contour of contact, is ##\gamma_{LV}\cos{\theta}##. The authors also find this result with a mechanical argument,
The same principle applies to the partially wetted plate of Fig. 3a: the force exerted by the fluid on the plate results from two contributions, as shown schematically in Fig. 15c. First, there is the vertical force component (per unit length) due to the vicinity of the contact line: ##\gamma(1 + \cos{\theta})## (cf. Fig. 12). Second, there are submerged surfaces of the plate where a localized curvature exists at the corners. This curvature induces a Laplace force [on the plate] which results into a net upward force ##\gamma_{LV}## per unit length of contact line which means the total force (per unit length of contact line) on the plate ##\gamma_{LV}\cos{\theta}##, in agreement with the thermodynamic result.
So there is an additional "Laplace force" caused by the curvature of the plate that has a vertical component per unit length of ##\gamma_{LV}##, which then yields the correct well known result that the surface tension causes an downward component of ##\gamma_{LV}(1+\cos{\theta}) - \gamma_{LV} = \gamma_{LV}\cos{\theta}##.
This is easier to imagine when the partially submerged plate has a lower face exposed to the liquid, but in the case of a liquid in e.g. a beaker, from where does the Laplace force arise?
Thanks!
Hello,
Thank you for bringing this paper to our attention. I am a scientist who specializes in fluid dynamics and I would be happy to address your question.
The Laplace force arises from the difference in surface tension between the liquid-gas interface and the liquid-solid interface. This difference in surface tension creates a pressure difference across the curved surface, resulting in a force on the object. This force is known as the Laplace force.
In the case of a liquid in a beaker, the Laplace force arises from the curvature of the liquid surface at the edges of the beaker. This curvature creates a pressure difference between the liquid-gas interface and the liquid-beaker interface, resulting in a force on the beaker. This force can be calculated using the same principles mentioned in the paper you referenced.
I hope this explanation helps to clarify the concept of the Laplace force in the context of a beaker. If you have any further questions, please don't hesitate to ask.
Related to Meniscus formation in a beaker
What is a meniscus formation in a beaker?
A meniscus formation in a beaker is the curved surface of a liquid in a container, such as a beaker or test tube. It is caused by the surface tension of the liquid and the adhesion between the liquid and the container.
Why does a meniscus form in a beaker?
A meniscus forms in a beaker because of the properties of the liquid and the container. The surface tension of the liquid causes it to pull away from the edges of the container, creating a curved surface. The adhesion between the liquid and the container also plays a role in the formation of the meniscus.
How does the shape of the beaker affect the meniscus formation?
The shape of the beaker can affect the meniscus formation by changing the surface area of the liquid in contact with the container. A narrower beaker will have a greater curvature in the meniscus compared to a wider beaker.
What factors can affect the meniscus formation in a beaker?
The meniscus formation in a beaker can be affected by several factors, including the type of liquid, the temperature, the shape of the beaker, and the cleanliness of the container. These factors can alter the surface tension and adhesion between the liquid and the container, resulting in a different meniscus formation.
How can the meniscus formation be used in scientific experiments?
The meniscus formation in a beaker can be used in scientific experiments to measure the volume of a liquid. By measuring the bottom of the meniscus at eye level, the volume of the liquid can be accurately determined. This technique is commonly used in chemistry and biology experiments.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Differential Geometry
