I Mercury as a plasma at 150 Kelvin
The discussion centers on the feasibility of creating mercury plasma at 150 Kelvin, with participants questioning the validity of such a theoretical engine. It is noted that at this temperature, mercury would likely be solid, contradicting the notion of it being in a plasma state. The low vapor pressure of mercury at 150 K means it cannot evaporate without significant heating, raising concerns about condensation on containment walls. Participants emphasize that pressurization alone cannot create plasma at such low temperatures. Ultimately, the thread concludes with a reminder to avoid engaging in pseudoscience discussions.
gary808
TL;DR Summary
Can you have mercury as a plasma at 150 kelvin?
I was reading up on a theoretical engine employing the following, “Mercury plasma pressurized at 250k atmospheres, at a temperature of 150 degrees kelvin (-123° C), and swirled within its accelerator to 50k RPM.”
Does pressurizing mercury so much somehow allow a plasma to form at such sub-zero temperatures?
This seems to fly in the face of what I understand should be super-heated plasma.
Might help to say where you read it.
Likes russ_watters
Or maybe not, since the source was not valid. :wink:
@gary808 -- your question is "Can you have mercury as a plasma at 150 kelvin?" right? What defines a plasma? What parameters (like pressure) can affect the plasma state other than temperature?
Likes gary808 and Ibix
Likes vanhees71, gary808, berkeman and 1 other person
Yes. My point is in debunking pseudo-science. Just wanted to double-check with the experts. Pressurization isn't a factor. If it's 150 kelvin, then it is likely a solid, or else it's not 150 kelvin but a super-heated plasma instead.
Likes vanhees71
We don't debunk pseudoscience at PF. Thread is closed.
Thread ''splain the hydrostatic paradox in tiny words'
This is (ostensibly) not a trick shot or video*. The scale was balanced before any blue water was added. 550mL of blue water was added to the left side. only 60mL of water needed to be added to the right side to re-balance the scale. Apparently, the scale will balance when the height of the two columns is equal. The left side of the scale only feels the weight of the column above the lower "tail" of the funnel (i.e. 60mL). So where does the weight of the remaining (550-60=) 490mL go...
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
11K
15K
23K
