Mercury Precession & GR Calculation Impact
  • Thread starter zincshow
  • Tags
    Precession
In summary: I'm sorry, but I don't see what we are debating about, I'm agreeing with you that the paper is wrong :-)To summarize, the paper suggests that the force inside a ring (modeled as a collection of point masses) is null, while in reality, it is only null at the center, and non-null everywhere else. This is due to the difference in the formula for infinitesimal mass between a ring and a shell. The paper is incorrect in this aspect, and the correct solution can be found by using the non-null potential instead of the force. This has implications for understanding the behavior of the gravity inside a ring and its effects on objects near it
  • #36
That is a strawman, starthaus. The authors said
If [itex]ds_1[/itex] and [itex]ds_2[/itex] are the arc lengths subtended by differential angular element [itex]d\alpha[/itex] and if [itex]a[/itex] is small compared to R11
[tex]dm_i = \lambda ds_i \simeq l_i \lambda d\alpha \qquad\qquad(2)[/tex]
The astute reader will note that Eq. (2) will not be valid for values of [itex]a\sim R[/itex], since the angle [itex]d\alpha[/itex] would subtend a mass larger than [itex]ds_i[/itex] by a factor of [itex](\cos \alpha)^{-1}[/itex]. Since the orbits of Venus and Mercury differ by approximately a factor of 2, we repeated the calculation including the [itex](\cos \alpha)^{-1}[/itex] term. An exact solution could not be found, but a series expansion to terms of order [itex](a/R)[/itex] showed that the errors introduced by ignoring the [itex](\cos \alpha)^{-1}[/itex] term were of order of 2.3%.​
In other words, the authors explicitly acknowledged that this is an approximation and they checked the validity of the approximation.
  • #37
If [itex]ds_1[/itex] and [itex]ds_2[/itex] are the arc lengths subtended by differential angular element [itex]d\alpha[/itex] and if [itex]a[/itex] is small compared to [itex]R[/itex]11
[tex]dm_i = \lambda ds_i \simeq l_i \lambda d\alpha & (2)[/tex]
The astute reader will note that Eq. (2) will not be valid for values of [itex]a\sim R[/itex], since the angle [itex]d\alpha[/itex] would subtend a mass larger than [itex]ds_i[/itex] by a factor of [itex](\cos \alpha)^{-1}[/itex]. Since the orbits of Venus and Mercury differ by approximately a factor of 2, we repeated the calculation including the [itex](\cos \alpha)^{-1}[/itex] term. An exact solution could not be found, but a series expansion to terms of order [itex](a/R)[/itex[ showed that the errors introduced by ignoring the [itex](\cos \alpha)^{-1}[/itex] term were of order of 2.3%.​
Yes, I pointed that out. They acknowledged that it is a hack that isn't valid for a~R. It is a hack that it is never valid since it defies elementary geometry (the kind they teach in 9-th grade). You know where you can find a decent treatment.
  • #38
D H said:
The author's intent in this paper is "to show that the component of the precession of Mercury's perihelion due to the outer planets can be calculated easily at the undergraduate level." He did so quite admirably IMO. The mathematics is quite simple, and yet comes remarkably close to those obtained by "more advanced treatments."
Yes, I agree.
starthaus said:
The authors have inadvertently canceled out the square roods
You have not acknowledged that you made a mistake here.
I don't like your tone. The authors have not made a mistake, they have made a useful approximation. This is the kind of skill to which students should be exposed, because this type of thing is ubiquitous in physics. If an approximation were equal to the unapproximated expression, it wouldn't be an approximation.
It is a useful exercise to express the difference between
http://www.physics.princeton.edu/~mcdonald/examples/mechanics/price_ajp_47_531_79.pdf
and
http://farside.ph.utexas.edu/teaching/336k/Newton/node127.html
in terms of powers of r/a.
  • #39
and
Sure, it is. Or you can use the algorithm that I outlined in calculating the exact integral describing the resultant force exerted by a ring. Your choice.
20K
