What Is the Success Probability of Merged Bernoulli Processes X1 and X2?
In summary: X_k^{(2)} = 1 \big)$ $ \leq Pr\big(X_k^{(2)} = 1\big) \cdot 1 = 0.7 $ since conditioning cannot increase a probability, so the max is 0.7. Some calculus can be added by using the joint mass function to define a function of two variables, (this is the product of the mass functions) and then using the method of lagrange multipliers to find the maximum on the joint support.
marcadams267
Consider two Bernoulli processes X1 and X2 such that
X1[k] is a Bernoulli random variable with P=0.5 and
X2[k] is a Bernoulli random variable with P=0.7 for all k>=0
Let Y be a random process formed by merging X1 and X2, i.e. Y[k] =1 if and only if X1[k] = X2[k] = 1 and Y[k] = 0 otherwise.
a.) Solve for the success probability of Y if X1 and X2 are uncorrelated.
b.) Solve for the success probability of Y if E[X1[k]X2[k]] = 0.3.
c.) If E[X1[k]X2[k]] is constant for all k, find the minimum possible success probability of Y.
d.) If E[X1[k]X2[k]] is constant for all k, find the maximum possible success probability of Y.
My initial thought was that the success probability of Y was just the intersection of x1 and x2 (when both are equal to 1) or 0.7*0.5 = 0.35.
However, the way to problem is written suggests that correlation affects the probability. Can someone explain how this is so?
Edit: I've realized that the 2 bernoulli processes may not be independent, therefore, my initial understanding of the problem is wrong.
However, how do I use the information given (the correlation) to solve for the probability? What equation relates the two together, or what assumptions can I make about the problem given the correlation?
This is pretty hard to read with all the multiple indices and no LaTeX to be honest. The standard form I've heard for 'merging' bernouli (or poisson) processes is additive, though this problem clearly is using products here, i.e. you have
$Y_k = X_k^{(1)}\cdot X_k^{(2)}$
so $Y_k$ takes on values 0 and 1 and is Bernouli
if $X_k^{(1)}$ and $ X_k^{(2)}$ are uncorrelated, direct application of the definition tells you that
$E\big[X_k^{(1)}\cdot X_k^{(2)} \big] - E\big[X_k^{(1)} \big] \cdot \big[X_k^{(2)} \big] = 0$ i.e.
$E\big[X_k^{(1)}\cdot X_k^{(2)} \big] = E\big[X_k^{(1)} \big] \cdot \big[X_k^{(2)} \big] $
so your answer to (a) is
$p = E\big[Y_k\big] = E\big[X_k^{(1)}\cdot X_k^{(2)} \big] = E\big[X_k^{(1)} \big] \cdot \big[X_k^{(2)} \big] =0.5 \cdot 0.7$
because the probability of success is equal to the expected values of a bernouli
(b)'s answer seems to be given.
I'd like to see some work on your end for (c) and (d)
for c and d,
I'm visualizing it to be two sets of 10 spaces each. One has 5 items within it, and the other has 7.
_ _ _ _ _ x x x x x
x x x x x x x _ _ _
and
x x x x x _ _ _ _ _
x x x x x x x _ _ _
It counts as a logic 1 or success if both corresponding spaces are filled.
The minimum would then be 0.7 - 0.5 = 0.2
and the maximum would be 0.5
marcadams267 said:
for c and d,
_ _ _ _ _ x x x x x
x x x x x x x _ _ _
and
x x x x x _ _ _ _ _
x x x x x x x _ _ _
I think a visualization like this is very good here and you have the right answer. For a different look at this problem, consider
re: maximization
The thing to keep in mind is probabilities are in [0,1], so they are at most one. For the max we have
$p = E\Big[Y_k\Big] = E\Big[X_k^{(1)}\cdot X_k^{(2)} \Big] = Pr\big(X_k^{(1)} = 1, X_k^{(2)} = 1\big) = Pr\big(X_k^{(1)} = 1\big) \cdot Pr\big( X_k^{(2)} = 1 \big \vert X_k^{(1)} = 1 \big)$
$ \leq Pr\big(X_k^{(1)} = 1\big) \cdot 1 = 0.5 $
which is what we get when we condition on the first random variable. Now conditioning on the second bernouli gives
$p = Pr\big(X_k^{(1)} = 1, X_k^{(2)} = 1\big) =Pr\big(X_k^{(2)} = 1, X_k^{(1)} = 1\big) = Pr\big(X_k^{(2)} = 1\big) \cdot Pr\big( X_k^{(1)} = 1 \big \vert X_k^{(2)} = 1 \big) $
$\leq Pr\big(X_k^{(2)} = 1\big) \cdot 1 = 0.7 $
so putting these inequalities together we have
$p\leq 0.5 \leq 0.7$
and 0.5 is the answer as you've stated.
re: minimization
letting $A_k$ be the event that the first bernouli is 1 and $B_k$ be the event the second bernouli is one, we have
(this is the most basic form of inclusion-exclusion)
$P\Big(A_k \bigcup B_k\Big) = P\Big(A_k\Big) + P\Big(B_k\Big) - P\Big(A_k \bigcap B_k \Big) $
note this tells us
$P\Big(A_k \bigcup B_k\Big) \leq P\Big(A_k\Big) + P\Big(B_k\Big) $
(This is called the union bound)
because $0 \leq P\Big(A_k \bigcap B_k \Big) \leq 1$
and furthermore, since all probabilities are at most 1 we have
$P\Big(A_k \bigcup B_k\Big) \leq \min\Big(1, P\big(A_k\big) + P\big(B_k\big)\Big) = \min\Big(1, 1.2\Big) = 1 $
so we revisit
now rearrange terms
$P\Big(A_k \bigcap B_k \Big) = P\Big(A_k\Big) + P\Big(B_k\Big) - P\Big(A_k \bigcup B_k\Big) = 0.7 + 0.5 - P\Big(A_k \bigcup B_k\Big) = 1.2 - P\Big(A_k \bigcup B_k\Big) \geq 1.2 - 1 = 0.2$
as you've stated
FAQ: What Is the Success Probability of Merged Bernoulli Processes X1 and X2?
What is a Merged Bernoulli process?
A Merged Bernoulli process is a type of stochastic process where the outcomes of two or more independent Bernoulli trials are combined. It is often used to model the behavior of systems where multiple events can occur simultaneously.
What are the key characteristics of a Merged Bernoulli process?
The key characteristics of a Merged Bernoulli process include independence of the trials, each trial having only two possible outcomes (success or failure), and the probability of success remaining constant across all trials.
How is a Merged Bernoulli process different from a regular Bernoulli process?
A regular Bernoulli process involves only one trial with two possible outcomes, while a Merged Bernoulli process combines the outcomes of multiple independent trials. Additionally, the probability of success in a Merged Bernoulli process remains constant across all trials, while it can change in a regular Bernoulli process.
What are some real-world applications of a Merged Bernoulli process?
Merged Bernoulli processes are commonly used in fields such as telecommunications, finance, and biology to model the behavior of systems with multiple simultaneous events. They can also be used to study the reliability of complex systems and to analyze data in market research and social sciences.
How is a Merged Bernoulli process analyzed and evaluated?
Merged Bernoulli processes can be analyzed using statistical methods such as probability distributions and hypothesis testing. The results of the analysis can then be used to evaluate the performance and behavior of the system being modeled.
