Metal ball sticks to putty. Where does the energy go?
In summary, a 6.0kg metal ball moving at 4.0m/s collides with a 6.0kg ball of putty at rest and sticks to it, resulting in a final velocity of 2.0m/s for the combined mass. The metal ball loses 36J of kinetic energy in the collision, while the putty ball gains 12J of kinetic energy. The remaining energy is converted into other forms, such as heat and sound, due to the deformation of the putty. However, the conservation of momentum and conservation of total energy laws still hold true in this scenario.
Subrosian
A 6.0kg metal ball moving at 4.0m/s hits a 6.0 kg ball of putty at rest and sticks to it. The two go on at 2.0 m/s.
a) How much energy does the metal ball lose in the collision?
b) How much energy does the putty ball gain in the collision?
c) What happened to the rest of the energy?
For a):
[tex]E_{klose} = E_{k} - E_{k'}[/tex]
[tex]E_{k} = 1/2mv^2
= 1/2(6.0kg)(4.0m/s)^2 - 1/2(6.0kg)(2.0m/s)^2
= 36J
[/tex]
Another method I tried was:
[tex]
W = F \Delta d
=m( \Delta v/ \Delta t)*(v_{f}+v_{i})/2* \Delta t
=6.0kg(-2m/s)*(3m/s)
=-36J
[/tex]
b) is simple:
[tex]
E_{k} = 1/2mv^2
= 1/2(6.0kg)(2.0m/s)^2
= 12J
[/tex]
The only problem I have with this question is the last part, C. The thing is, the momentum was conserved completely, so the energy could not be lost from friction or sound. Here is an example of trying to find the velocity of the ball and putty combined if no energy was lost to heat/sound/friction/etc:
[tex]1/2(6.0kg)(v)^2 + 1/2(6.0kg)(v)^2 = 1/2(6.0kg)(4.0m/s)^2[/tex]
[tex]2v^2 = 48J*2/6.0kg[/tex]
[tex]v = \sqrt{8}[/tex]
Which is impossible because of
[tex]mv = m^{'}v^{'}[/tex]
[tex]6.0kg*4.0m/s = 12.0kg*\sqrt{8}m/s[/tex]
Which is clearly unequal.
I asked this question to my teacher and he said that the conservation of energy does not always work. That is a ridiculous answer :rolleyes:
I'm not sure why you say no energy will be lost to heat. The deformation of the putty will warm it up.
If energy was lost to heat, then why is the momentum the same?
Conservation of momentum and conservation of total energy are independent laws of physics.
Energy isn't lost, it's just converted into other forms of energy, such as heat.
What is "lost" in this particular problem is the kinetic energy associated with the center-of-mass motions of the two balls.
The center-of-mass momentum is, by definition, always equal to the total momentum of the system. But the center-of-mass energy is not the same as the total energy.
So, if the center of mass energy is not the same as the total energy, does that mean the answers to a) and b) are incorrect as well? They are also in the answer key.
The question is phrased wrongly: you answered correctly, but "energy" should be replaced by "kinetic energy", or "mechanical energy".
Given the way the question is phrased, and given your teacher's answer, I doubt he knows a lot of physics.
FAQ: Metal ball sticks to putty. Where does the energy go?
How does a metal ball stick to putty?
The sticking of a metal ball to putty is due to the phenomenon known as adhesion. Adhesion occurs when two different materials are attracted to each other at the molecular level. In this case, the molecules of the putty are attracted to the molecules of the metal ball, causing them to stick together.
Where does the energy go when a metal ball sticks to putty?
The energy involved in the sticking of a metal ball to putty is mostly converted into heat. When the two materials come into contact, their molecules interact and create friction, which generates heat energy. This is why the putty and the metal ball may feel warm after sticking together.
Why does the metal ball stick to putty, but not other materials?
This is due to the strength of the adhesive forces between the two materials. Putty has a high viscosity and is able to form strong bonds with the metal ball. Other materials may not have the same level of adhesion and therefore will not stick to the putty as strongly.
Can the metal ball and putty be separated after they stick together?
Yes, they can be separated but it may require a significant amount of force. The strength of the bond between the two materials will determine how difficult it is to separate them. In some cases, the putty may stretch or deform before breaking the bond with the metal ball.
Will the metal ball and putty stick together forever?
No, the metal ball and putty will eventually separate over time. The bond between them will weaken as the materials cool down and the energy dissipates. Additionally, external factors such as moisture or temperature changes can also affect the strength of the bond and cause them to separate.
