Metal colors and unoccupied levels
In summary, the color of a material results from the inability (or lesser ability) to absorb in that particular wavelength. Silver reflects light with nearly equal efficiency across the visible spectrum because its band structure has many unoccupied energy levels that can be populated by absorption of, and depopulated by emission of, visible light. Copper has its characteristic color because it has relatively fewer unoccupied energy levels that can be excited with violet, blue and green light. The material reflects at all wavelengths, but more light is emitted at lower frequencies (corresponding to yellow, orange and red)
lixy
Hi all,
It is my understanding that the color of a material results from the inability (or lesser ability) to absorb in that particular wavelength. Reading Atkins' "Physical Chemistry" (8th ed.), I run into a statement I couldn't quite get. On page 730 (chap. 20), he states the following:
So far it makes perfect sense. But then comes trouble:
On the other hand, copper has its characteristic colour because it has relatively fewer unoccupied energy levels that can be excited with violet, blue and green light. The material reflects at all wavelengths, but more light is emitted at lower frequencies (corresponding to yellow, orange and red)
If copper has fewer unoccupied energy levels that can be excited with violet, blue and green light, wouldn't that make it absorb less light of those colors and therefore exhibit a blue-ish color? And as far as I know (and as unambiguously stated in the end of the above quote), copper is red-ish.
Any light on this would be most appreciated. Thanks in advance.
Reflectivity of a metal in the visible-UV range is related to the plasmon dispersion of that metal (rather than to the single electron states). A plasmon is a vibrational mode of the entire free-electron gas living in the background of a periodic, positively charged lattice. This electron gas has a natural frequency of oscillation, known as the plasma frequency. For most metals, the plasma frequency lies somewhere in the far UV region.
When the frequency of the incident light is smaller than the plasma frequency, the electron gas responds to the oscillating E-field and screens it out. So, for frequencies below the plasma frequency, the light can not be transmitted through the metal and hence, is almost entirely reflected back. When light has a frequency higher than the plasma frequency, the electron gas can not respond fast enough to screen out the oscillating E-field inside the metal. As a result, such high frequencies are almost entirely transmitted through the metal (and hence, most metals are transparent to UV).
Now, for most metals, the plasma frequency is far into the UV regime, making the metal reflact all visible wavelengths almost equally. This is why most metals look a lustrous silvery-white. Some metals, like gold and copper, have a lower plasma frequency (closer to violet/near UV regime), making them better reflectors of lower frequency light than of high frequency light. As a result, the reflection spectrum of such metals is weighted more at the lower frequencies, giving them a reddish or yellowish color.
Likes YoungPhysicist
Wow! That was heavy but extremely enlightening.
Thanks a million for sharing.
FAQ: Metal colors and unoccupied levels
What are metal colors?
Metal colors refer to the visible light that is reflected by a metal surface. Different metals have distinct colors due to their unique physical and chemical properties.
What causes metals to have specific colors?
The color of a metal is determined by its electronic structure, specifically the arrangement of electrons in its unoccupied energy levels. This is known as the band structure, and it results in certain wavelengths of light being absorbed or reflected by the metal.
Why do some metals have more than one color?
Some metals have multiple colors because their band structure changes when they are exposed to different temperatures, pressures, or other external factors. This can result in a different arrangement of electrons and therefore a different color.
Can metal colors change over time?
Yes, some metals can undergo chemical reactions or corrosion over time, which can alter their electronic structure and thus their color. For example, copper can turn green due to oxidation.
Why are some metal colors more vibrant than others?
The vibrancy of a metal's color is determined by the intensity of light that is reflected by its surface. This can depend on factors such as the metal's purity, surface texture, and surrounding lighting conditions.
