Metal Magnetic Flux 9: Calculate Induced Current & Resistance
In summary: V}{I} = \frac{\epsilon}{I} = \frac{.0736T/s}{.25A} = 0.294 ohmIn summary, the problem involves two sliding metal bars moving at constant speeds in opposite directions along parallel rails in a uniform magnetic field. Using Faraday's law of induction, the rate of change of magnetic flux within the loop formed by the sliders and rails can be calculated. The induced current flows in a direction determined by the direction of the magnetic field and the velocity of the bars. If the current is 0.25 A, the total resistance of the loop can be calculated using Ohm's Law. The solution involves using the equation \frac{d\
dangish
75
9. Two sliding metal bars of length l = 15.0 cm are moving along two parallel rails, in
opposite directions, with constant speeds of v = 0.7 m/s, as shown in the figure below.
The rails are located in a uniform magnetic field with a magnitude 0.35 T that is directed
into the page as shown.
(a) Calculate the rate of change of magnetic flux within the loop formed by the sliders
and the rails.
(b) In what direction does the induced current flow around the loop? Indicate this clearly
on the diagram and briefly justify your answer.
(c) If that current is 0.25 A, calculate the total resistance of the loop.
The picture is in the attachment if you need it.
I have an exam on monday, I am not very good at this stuff, the professors not giving solutions and I can't figure this one out.
only equation I found that was relevant is,
Integral of B.ds = u0I + u0e0 x(dfluxe/dt)
and integral of E.ds = -dfluxb/dt
Can someone please help me!
To solve the problem you need to useFaraday's law of induction
In particular, [tex]\frac{d\Phi}{dt}[/tex] = [tex]\epsilon[/tex] = Bvl (This formula is in the "Direct evaluation of the change in flux" paragraph).
Substitute and you have your answer for a).
Part b) is just some basic knowledge of the direction of B knowing the direction of velocity and current.
For part c) you can use your [tex]\epsilon[/tex] found in a) as Voltage ([tex]\epsilon[/tex] stands for electromotive force, which is basically equivalent to voltage) and find R using Ohm's Law.R.
so that e is the rate of change of magnetic flux? what are the units for that? something per second I would imagine.
actually I guess the units are Tesla/s
And for part b you can just change that to voltage?
also, since there are two velocities, -0.7 and +0.7 m/s
which one should I use?
[tex]\epsilon[/tex] is just a voltage, so it's measure in Volts.
How about using a summation with v=1.4ms-1 and then v=-1.4ms-1?
I vaguely understand what you mean by summation there
LaTeX Code: \\epsilon = (.35T)(.7m/s)(.15m) = .0368T/s is what I did for part a.)
Ok, let's think about the process itself.
The change in magnetic flux is proportional to the area swept by each bar.
In 1 second, the bar traveling to the right would have swept Acm^2.
During the same time, bar traveling to the left would have swept how much?
It would have swept the exact same amount of area?
-Acm^2
Areas are not vectors. So just A cm^2, right?
fair enough, where does this lead us exactly? I still don't know what to use for the velocity
You should have two terms.
One for +0.7ms-1, one for -0.7ms-1, but you can neglect the minus of the latter.
so would I have to use the same equation twice?
or are you saying I can just use e=(.35T)(.7m/s)(.15m)
you have to use it twice.
e1=(.35T)(.7m/s)(.15m) = .0368T/s
e2=(.35T?(.7m/s)(.15m)=.0368T/s
etot= e1+e2 = .0368T/s + .0368T/s = .0736T/s
is this correct?
I believe so.
thank you good sir, patience is a virtue, especially when dealing with me.
Cheers!
You're welcome.
R.
FAQ: Metal Magnetic Flux 9: Calculate Induced Current & Resistance
What is metal magnetic flux?
Metal magnetic flux refers to the measure of the magnetic field passing through a metal object. It is represented by the symbol Φm and is measured in units of webers (Wb).
How do you calculate induced current in a metal object?
Induced current in a metal object can be calculated using the equation I = Φm/t, where I is the induced current, Φm is the metal magnetic flux, and t is the time in seconds.
What is the relationship between induced current and resistance in a metal object?
The induced current in a metal object is directly proportional to the resistance of the object. This means that as the resistance of the object increases, the induced current also increases.
How do you calculate the resistance of a metal object?
The resistance of a metal object can be calculated using the equation R = ρl/A, where R is the resistance, ρ is the resistivity of the metal, l is the length of the object, and A is the cross-sectional area of the object.
What factors can affect the induced current and resistance in a metal object?
The factors that can affect the induced current and resistance in a metal object include the strength of the magnetic field, the speed at which the object moves through the field, and the properties of the metal such as its conductivity and resistivity.
