Metal or Insulator: Examining Resistance in Multiple Directions
In summary, the type of material (metal or insulator) is typically determined by the size of the gap. However, when measuring resistance in different directions, such as x and y, there can be variations. Additionally, as temperature increases, the resistance also changes, with metal showing an increase and insulators/semiconductors showing a decrease. In cases where a material appears to be a metal in one direction but not in another, it is possible to consider it a metal only in that specific direction. This phenomenon is commonly seen in laminated core transformers and layered materials, such as cuprate superconductors. Graphite is an example of a material with anisotropic resistance, with higher resistance in the c direction compared to the
howl
Generally, a material is metal or insulator is simply determined by the gap. But if we view it in another way, to measure the resistance in different direction, says x and y, and there are usually different. And then measure the resistance change with temperature. Usually, the resistances goes up with temperature increases is metal, while resistances goes down is insulator, or semiconductor. If one finds that a material in x direction looks like metal in this resistance experimental, while in y no, is this situation possible? If so, could we say this material is metal just in x direction?
We use such material in laminated core transformers. The metal laminations are separated by non-conducting varnish. This is used to limit eddy current losses in the core:
https://qph.fs.quoracdn.net/main-qimg-99d6364e32355e6c00ab138131eeb3c5
Likes aaroman and CWatters
The cuprate superconductors are made up of layers of different atoms and molecules.
Along the so-called [a,b] plane where the Cu-O planes lie, it is very conducting, almost like a typical metal. Along the c-axis (vertical direction), the resistivity can be several orders of magnitude higher, and often considered to be insulating.
There are many layered materials that behave this way, so it isn't that exotic anymore.
Zz.
Likes aaroman and NathanaelNolk
As far as I know graphite is such a material. Its resistivity is much higher in the c direction than in the a-b plane. I do not know about its metallicity though.
Thanks for your answers!
I know that there is anisotropy in many materials, what I want to know is when temperature goes up, resistance in x increases, while y no, is it usual?
Related to Metal or Insulator: Examining Resistance in Multiple Directions
What is the purpose of the experiment?
The purpose of the experiment is to investigate the resistance of different materials (metal and insulator) in multiple directions and determine their conductivity properties.
What equipment is needed for the experiment?
The equipment needed for the experiment includes a power source, a voltmeter, an ammeter, wires, metal and insulator samples, and a circuit board.
How is resistance measured in the experiment?
Resistance is measured by calculating the ratio of voltage to current using Ohm's law (R=V/I). The higher the resistance, the lower the conductivity of the material.
What factors can affect the resistance of a material?
The resistance of a material can be affected by its physical properties such as length, cross-sectional area, and temperature. The type of material and its composition can also impact its resistance.
What are the potential applications of this experiment?
This experiment can help in understanding the behavior of different materials in electrical circuits and can have practical applications in designing and optimizing electronic devices. It can also lead to advancements in materials science and contribute to the development of new technologies.
  • Atomic and Condensed Matter
  • Materials and Chemical Engineering
15K
  • Mechanical Engineering
