Metal sphere in an electric field
In summary, the question pertains to a metal sphere in a uniform electric field and how the symmetry of the sphere affects the potential of the xy plane. While the sphere itself may have spherical symmetry, the presence of the external electric field introduces a cylindrical symmetry. This means that the potential on the xy plane is not zero, but can be adjusted by adding a constant potential. Ultimately, the entire situation must be considered, not just the sphere alone, to determine the symmetry and potential of the xy plane.
Clara Chung
304
The question is exactly the same as this question
https://physics.stackexchange.com/questions/250297/metal-sphere-in-a-uniform-electric-field
However, it says "Then by symmetry the entire xy plane is at potential zero" in the book. I don't understand this.
I understand the sphere is an equipotential... but I don't get the idea of how the symmetry of the sphere is related to the region outside the sphere
Likes Delta2
Because of the external electric field, you don't have spherical symmetry in this problem anymore. Instead, you have a cylindrical symmetry. You can't just look at the sphere alone to determine what symmetry you have. You have to consider the entire situation.
Likes timetraveller123, Clara Chung and Delta2
Because the induced charges is similar on the northern and southern hemisphere. If it were just the sphere with same charge distribution without the external electric field the xy plane would be zero potential because the potential would cancel out in pairs. With the addition of the external electric field you just add constant potential to the XY plane. You are free to choose the constant.
Likes Clara Chung
Related to Metal sphere in an electric field
1. What is a metal sphere in an electric field?
A metal sphere in an electric field is a type of experiment used to demonstrate the effects of electric fields on conductive materials. It involves placing a metal sphere in the presence of an electric field and observing the resulting behavior.
2. How does a metal sphere behave in an electric field?
A metal sphere placed in an electric field will experience a force due to the interaction between the electric field and the electrons in the metal. This force causes the electrons to move within the metal, resulting in a redistribution of charge and an induced electric field within the sphere.
3. What factors affect the behavior of a metal sphere in an electric field?
The behavior of a metal sphere in an electric field is affected by factors such as the strength of the electric field, the size and shape of the sphere, and the material of the sphere. A larger sphere or a stronger electric field will result in a greater force and a more noticeable effect.
4. What is the purpose of conducting a metal sphere in an electric field experiment?
The purpose of this experiment is to demonstrate the principles of electric fields and their effects on conductive materials. It can also be used to investigate the behavior of electric fields and to calculate the strength of an unknown electric field.
5. What are some real-world applications of a metal sphere in an electric field experiment?
This type of experiment has various applications in the fields of physics and engineering. It can be used to study the behavior of electric fields in different materials, to design and test electrical equipment, and to understand the behavior of lightning strikes. It also has practical applications in areas such as electrostatic painting and electrostatic precipitation in air pollution control.
  • Electromagnetism
  • Classical Physics
10K
