Steelwolf
- 104
- 179
- TL;DR Summary
- Wondering if the recently proven Metallic Hydrogen, which is apparently meta-stable, would be useful for extremely fine cutting instruments.
I have never posted a Q here before, but as an old knife and swordmaker, when I saw this article: https://phys.org/news/2019-06-french-scientists-metallic-hydrogen.html
It suddenly piqued my interest: IFF one can create a large enough, meta-stable crystal of metallic Hydrogen, and were able to shape and fix the blade into the proper fixture:
How would that work as a microtome type blade?
Most knives in use use rather large atoms in crystalline or quasi-crystalline form as for the ceramic knives. But I would think that a blade that was essentially formed of a crystal composed of Single protons and Proton-neutron pairs in a shared electron 'cement' or maybe electron 'epoxy' would be better term, but the crystalline edge would be finer than most atomic bonds in larger-atom structures.
Such a knife, properly affixed, should be able to make nearly perfect cuts of a material, even up to diamond, and leave a surface that needs no polishing to see relevant details.
Of course, so far we have only miniscule amounts of metallic Hydrogen being formed in diamond anvil presses, yet if a large enough sample should be made, I would expect it to be able to make The Sharpest Blade of physical materials as opposed to laser or electron beam cutting work.
It may be a major field in itself, if we can develop a method to create the material in bulk.
But, in general, asking if such could be made and what problems one might run into with it?
Obviously there may be certain rates of cutting that would cause friction and make the Hydrogen to 'de-mineralize' back to liquid and rapidly back to gas in an explosively quick manner, or certain chemical or magnetic situations that may cause same so such limits would have to be learned, but imagine being able to take one atom thick slices of any material, or as thick of a slice as will still hold together, and the knife blade itself could be extremely thin in the body as it should not take much friction to effect such cuts. Leaving perfectly cut surfaces with no need for polishing.
It may end up being better than lasers or obsidian. But, is it do-able? And at what kind of costs?
