MHB Metallurgy- Road Construction - linear equation
To produce 18-karat gold from 15 grams of 14-karat gold, 10 grams of pure gold should be melted. In road construction, after the new machine works for 4 hours, it completes one-third of the job, leaving two-thirds for the older machine. The older machine, which takes 16 hours to complete half a mile, will take approximately 10 and 2/3 hours to finish the remaining work. A straightforward method for the second problem involves calculating the portion completed by the new machine and determining the remaining work for the older machine. Overall, both problems can be approached with different methods for clarity and verification.
paulmdrdo1
1. Metallurgy. How much pure gold should be melted with
15 grams of 14-karat gold to produce 18-karat gold?
2. Road Construction. A new machine that deposits cement
for a road requires 12 hours to complete a one-half mile section of road. An older machine requires 16 hours to pave the same amount of road. After depositing cement for 4 hours, the new machine develops a mechanical problem and quits working. The older machine is brought into place and continues the job. How long does it take the older machine to complete the job?
my attempt on 1st problem
x = amount of pure gold
$15\frac{14}{24}+x=\frac{18}{24}(15+x)$
x = 10 grams
for 2nd I get the correct answer but I'm not sure If I modeled the situation correctly.
$\frac{0.5}{12}\cdot 4+\frac{0.5}{16}\cdot x=0.5$
x = 10 and 2/3 hr.
can you give me a more straight forward method for problem 1 and 2. just for variety-of-method's sake.
thanks!
Mathematics news on Phys.org
x = 10 grams
I agree.
x = 10 and 2/3 hr.
To help checking, it's good to say what $x$ represents. I assume it is the time it take the older machine to complete the job. Then $4/12$ is the part of the road completed by the new machine, and $x/16$ is the part completed by the old machine. Together they make up 1, i.e.,
\frac{4}{12}+\frac{x}{16}=1.
This equation is equivalent to yours, but I don't understand what 0.5 represents in your equation.
I would solve the second problem without equations. The part completed by the new machine is 4/12 = 1/3. The remaining part is 1 - 1/3 = 2/3. Therefore, the old machine has to work 16 * 2/3 = 10 2/3.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
