Metaphor for orbital angular momentum?
In summary, the difference between spin angular momentum and orbital angular momentum can be compared to Earth's rotation on its own axis and its orbit around the Sun respectively. While orbital angular momentum has a classical analog, spin angular momentum does not and is unique to quantum mechanics. It is important to understand that spin is a fundamental aspect of particles in the quantum world and cannot be fully explained through classical analogies.
NanaToru
24
I've been tutoring for chemistry and someone asked me to clarify the difference of spin angular momentum and orbital angular momentum without math.
I was trying to think of a metaphor, but I wanted to make sure it's a fair one--the spin angular momentum is like Earth rotating on its own axis and orbital angular momentum of an electron in an orbital is analogous to the rotation of the Earth around the Sun. Of course this ignores a lot of other implications like resultant magnetic momentum, but it was the simplest one I could come up with.
Is this fair? I"m worried that they might get into their head that electrons then spin on a specific path like the Bohr model, but I'm not sure what else to compare it to. And of course this only applies to hydrogen like species but again, I was a bit on the spot... I'd love to give them a better metaphor.
Chemistry news on Phys.org
Orbital angular momentum does have classical analog in that they can be represented as an operator product
$$ \hat{\mathbf{L}} = \hat{\mathbf{r}} \times \hat{\mathbf{p}} $$
Which also holds in classical dynamics, such as that in planet's orbit. So it's a relatively fair analogy and won't be that misleading for a mere metaphor.
Unfortunately the spin angular momentum has no classical analog, the spin operators (to the best of my knowledge) cannot be represented by any other operators which have classical analogue as is the case for orbital angular momentum being a vector product between position and momentum vectors. It may be safer to just "dictate" to your student that spin angular momentum is just there for every particle, i.e. there happened to be another angular momentum aside from orbital angular momentum in the quantum world, this being one of the distinguishing trademarks of quantum mechanics as opposed to classical mechanics. Forcing the notion that spin in QM is analogue to the spin in CM won't get your student anywhere in understanding even the basic nature of the former case.
Related to Metaphor for orbital angular momentum?
1. What is orbital angular momentum?
Orbital angular momentum refers to the rotational motion of a particle or object around a fixed point or axis. In physics, it is often represented by the symbol L and is measured in units of angular momentum (such as joule-seconds or kilogram-meter squared per second).
2. How is orbital angular momentum different from spin angular momentum?
Orbital angular momentum and spin angular momentum are two types of angular momentum in quantum mechanics. Orbital angular momentum is associated with the motion of a particle in an orbital or circular path, while spin angular momentum is an intrinsic property of a particle that is not dependent on its motion.
3. What is the metaphor for orbital angular momentum?
The metaphor for orbital angular momentum is often described as a spinning top or gyroscope. Just as a spinning top maintains its rotation around a fixed axis, the orbital motion of a particle also maintains its rotation around a fixed point or axis.
4. How is orbital angular momentum measured?
Orbital angular momentum is measured using the principle of conservation of angular momentum. This means that the total angular momentum of a system remains constant, so any change in the orbital angular momentum of a particle will result in an equal and opposite change in the angular momentum of another particle or system.
5. What are the applications of orbital angular momentum?
Orbital angular momentum has various applications in physics, including in the study of atomic and molecular structures, quantum computing, and optical communications. It is also crucial in understanding the behavior of particles in electromagnetic fields and in determining the properties of particles in quantum mechanics.
  • Quantum Physics
  • Mechanics
