Meteor impact - Heat vaporization and capacity
In summary, the meteor created a heat explosion that vaporized a significant amount of water in the ocean.
henrco
47
I believe my attempt below is correct but I'm not 100% sure, any guidance welcome.
1. Homework Statement
Suppose a meteor of volume 1000 km3, density 5000 kg m-3 and speed 30000 km hr-1 crashed into the ocean and 10% of the impact energy was converted directly into heat.
i) Estimate the volume of water that would be evaporated.
ii) Given that the area of the oceans is 3.9 × 1015 m2, estimate the resulting change in their depth.
(The specific latent heat of vaporization for water is 2257 kJ kg-1 and the specific heat capacity of water is 4.18 kJ kg-1K-1. Assume that the mean ocean temperature is 4°C and that seawater has a density of 1000 kg m-3. Indicate clearly any further assumptions you make.)
i) Kinetic Energy = 0.5 mv^2
ii) Latent Heat Q = m l (m is the mass and l is the latent heat of vaporization)
iii) Heat Capacity = m c ΔT (m is the mass, ΔT is change in temp and c is the specific heat capacity)
Work the mass of the meteor : M = ρV = (5000)(1000x10^3) = 5x10^9 kg
Kinetic energy of meteor: 0.5(5x10^9)(3x10^7)^2 = 2.25x10^24 Joules
10% of kinetic energy turns to heat : 10%(2.25x10^24) = 2.25x10^23 Joules
ΔT (Change in temp required from 4C to 100C degrees or 277.15K to 373.15) : 96K
Energy required to heat 1kg of salt water by 96K.
Qheat = Mwater c ΔT = 1kg x (4.18) 96 = 401.28 kJ
Energy required to vapourize the salt water = 2257kJ/kg
Total energy required to heat and vapourize 1 kg of water = 2257 + 401.28 = 2658.28kJ
Determine the mass of water that is evaporated : 2.25x10^23 / 2658.28x10^3 = 8.46 x 10^16 kg
Convert this mass into volume: V = M/ρ = (8.46 x 10^16) / 1000 = 8.46 x 10^13 m3
Answer 1) Volume of sea water vaporized = 8.46 x 10^13 m3
Answer 2) Change in Ocean depth: (8.46 x 10^13)/ (3.9 x 10^15) = .022 m or 2.2cm
How many cubic meters are in 1 cubic kilometer?
Remember, 1 cubic kilometer has the same volume as a cube which measures 1000 m on each edge.
What are the units of the velocity of the meteor on impact? Do those units produce joules for kinetic energy?
A temperature difference of 1° C = a temperature difference of 1° K.
There is no need to convert to absolute temperature when calculating temperature differences.
You've got some serious errors in your unit calculations which need fixing.
Likes henrco
Thanks for your reply and for pointing out my mistakes.
Here are my corrections. For the last section "Energy required to heat 1kg..." you said I have serious unit calculations.
But apart from the ones that were carried through from my earlier mistakes I couldn't spot new ones?
I am however not sure about my answer to part 2) of the question.
Convert the volume of the meteor from km^3 to m^3
1000 km^3 = 1x10^12 m
Work the mass of the meteor : M = ρV = (5000)(1x10^12) = 5x10^15 kg
Convert the velocity of the meteor from km/hr to m/s.
30,000 km/hr = 8333m/s
Kinetic energy of meteor: 0.5(5x10^15)(8333)^2 = 1.7x10^23 Joules10% of kinetic energy turns to heat : 10%(1.7x10^23) = 1.7x10^22 Joules
ΔT is difference in temperate from 4 to 100 degrees which is 96 degrees
Energy required to heat 1kg of salt water by 96 degrees
Determine the mass of water that is evaporated : (1.7x10^22) / (2658.28x10^3) = 6.53 x 10^15 kg
Convert this mass into volume: V = M/ρ = (6.53 x 10^15) / 1000 = 6.53 x 10^12m3
Answer 1) Volume of sea water vaporized = 6.53 x 10^12 m3
Answer 2) Change in Ocean depth: (6.53 x 10^12)/ (3.9 x 10^15) = 1.67x10^-3 m
Corrections look good.
The change in ocean depth due to vaporization of the water due to meteor impact < 2 mm.
Likes henrco
Thanks for you help. Greatly appreciated.
Related to Meteor impact - Heat vaporization and capacity
What is the process of heat vaporization?
Heat vaporization, also known as heat of vaporization, is the amount of energy that is required to change a substance from a liquid to a gas state at a constant temperature and pressure.
Can meteor impact cause heat vaporization?
Yes, a meteor impact can cause heat vaporization as the immense heat and pressure generated during the impact can vaporize the surrounding materials.
What factors affect the heat vaporization of a substance?
The heat vaporization of a substance is affected by its molecular structure, temperature, and pressure. Substances with stronger intermolecular forces require more energy to vaporize, while higher temperatures and lower pressures can increase the rate of vaporization.
How does heat vaporization impact the environment?
Heat vaporization can have a significant impact on the environment, as it can release large amounts of energy and create extreme heat and pressure. This can cause destruction and alter the surrounding ecosystem.
What is the role of heat capacity in meteor impact?
Heat capacity, also known as specific heat, is the amount of heat required to raise the temperature of a substance by one degree. In a meteor impact, heat capacity plays a crucial role in determining how much energy is needed to vaporize the surrounding materials and the resulting effects on the environment.
