Methane mixed with air at 16:1 by mass
In summary, the mass fraction of argon, nitrogen, oxygen, and methane in the final mixture is 29.4%, 16.7%, 7.8%, 2.4%, and 0.9% respectively.
igowithit
Methane is mixed with air at a 16:1 per mass ratio at 1atm and 298K. Calculate the mass fraction of argon, nitrogen, oxygen, and methane in the final mixture
First, change mass ratio of reactants to mole ratio
\frac{16 g CH_4}{16 g/mol CH_4} = 1 mol CH_4
\frac{1 g Air}{28.97 g/mol Air} = 0.0345 mol Air
or in nice round terms,
29 mol CH_4
1 mol Air
leading to
29 CH_4 + 1*(0.00933Ar + 0.7809N_2 + 0.2095O_2) = aCH_4 + bCO_2 + cAr + dN_2 + eO_2 + fH_2O + gH_2 + hOH
I feel like this is way too many products to reasonably allow for a timely solution. Anyways, setting up a mass balance for each of the 5 elements in the equation leads to
C: 29 = a + b
H: 4*29 = 4a + 2f + 2g + h
Ar: 0.00933 = c
N: 2*0.7809 = 2d
O: 2*0.2095 = 2b + 2e + f + h
we now know c and d just from these equations leaving us with 3 equations but 7 unknowns (a,b,e,f,g,h,and T). Set up ##K_p## equations based of stoichiometric equations. I'll make a guess at temperature, therefore I only have to set up 3 ##K_p## equations to go with the 3 mass balance equations I already have. However, this is where I'm stuck. When I do this, I end up with crazy complex equations that even Matlab can't solve for the coefficients.
I feel like I have entirely too many products, but I don't know how to pick and choose which ones to keep and which ones to remove. Is there any easier path to take for this problem?
The problem statement doesn't say that the mixture is ignited. Are you sure it is?
No, the problem statement does not specify whether or not the mixture is in combustion or not. It simply states it is a mixture. I'm not sure how that changes the problem though?
EDIT: Wait, I think I see what you're saying now. I'm trying to work as a combustion problem and it's actually just an extremely simple mixture of two gases. That makes things much easier.
Likes Chestermiller
Actually a mixture of several gases, as air is a mixture itself. But I agree on the "simple" part :wink:
igowithit said:
Methane is mixed with air at a 16:1 per mass ratio at 1atm and 298K. Calculate the mass fraction of argon, nitrogen, oxygen, and methane in the final mixture?
It is clearly written that it is methane mixed with air (1 atm is an indication of air) so it is 16 parts by mass of methane and one part by mass air (at 1 atm and 298K).
Use information that density of air is 1.2754 g./L (at 298K )to calculate the mass of each component of gas with its percent composition by mass .Now 1L of air is added to 16*1.2754 g of methane and this will give you 16:1 ratio .Divide each mass of individual gas (obtained above)with total mass of the sample in 1L (1.2754+16*1.2754) to get mass fraction of each component of the gas.
Related to Methane mixed with air at 16:1 by mass
1. What is the significance of the ratio 16:1 in methane mixed with air by mass?
The ratio 16:1 refers to the mass ratio of methane to air when they are mixed. This means that for every 16 grams of methane, there is 1 gram of air in the mixture.
2. Why is methane commonly mixed with air at a 16:1 ratio by mass?
The 16:1 ratio is commonly used because it is the stoichiometric ratio for complete combustion of methane. This means that when methane and air are mixed in this ratio and ignited, all of the methane will react with the oxygen in the air to form carbon dioxide and water.
3. What is the purpose of mixing methane with air in this ratio?
Mixing methane with air in a 16:1 ratio by mass is often used in industrial processes to create a stable and efficient fuel mixture for combustion. It is also used in laboratory experiments to study combustion reactions and to calibrate gas sensors.
4. How does the mass ratio of methane to air affect the properties of the mixture?
The mass ratio of methane to air can affect the flammability, energy content, and emissions of the mixture. A higher ratio of methane to air will result in a more flammable mixture with higher energy content, while a lower ratio may produce lower emissions.
5. Can the 16:1 ratio be adjusted for different applications?
Yes, the ratio of methane to air can be adjusted depending on the specific needs of the application. For example, in some cases, a higher ratio may be used for increased energy output, while a lower ratio may be used for reduced emissions. However, the 16:1 ratio is commonly used as a baseline for methane-air mixtures.
9K
  • Mechanical Engineering
13K
