Method for instatnt cooling of water
In summary, the conversation is discussing suggestions for efficiently cooling 1 cubic meter of water from 25C to 10C. There are suggestions such as using a coolant with good conductivity and quickly supplying fresh coolant, as well as using liquid nitrogen or simply using a thermometer kept in a freezer to measure the temperature. The definition of efficiency is also questioned, whether it refers to the use of minimal energy, resources, or technology.
alibaba2
32
any suggestion on the most efficient method to cool water from 25C to 10C . the volume of the water is 1 cubic meter...?
thank you
This sounds like homework, so I'm moving it to the homework help section of the site. Please post further homework questions there.
Furthermore, we will not give you any answers. You'll need to explain your thoughts to us, and explain how and why you're stuck, before we can help you.
- Warren
And what do you mean by "efficient"? Is the cooler going to be constrained to be powered by electricity or fossil fuels or something? Or are you just looking for the fastest and easiest way (like drop in a big ice cube)?
Well, What about dropping it in liquid nitrogen?? :P:P
Some hints - the cooling rate will depend on;
1, the temperaure difference between the water and the collant
2, the conductivity between the water and the collant
3, how quickly you can supply fresh collant.
Efficency is a bit more difficult, do you mean you want to use the least extra energy, the least parts, the least equipement, or just the fastest solution?
With a nod of the head to mgb_phys, umm, put it in something really, really cold with no insulation for just the right length of time?
Effecient how? Physically? Finacially? Technologically (ease of use)?
How about “measure it with a thermometer that's been kept in a freezer.” That's pretty efficient, no actual cooling of water required.
FAQ: Method for instatnt cooling of water
What is the purpose of a method for instant cooling of water?
The purpose of a method for instant cooling of water is to quickly lower the temperature of water to a desired level for consumption or use in various scientific experiments or processes.
How does the method for instant cooling of water work?
The method for instant cooling of water typically involves using a refrigerant or cooling agent, such as ice or liquid nitrogen, to rapidly transfer heat away from the water and lower its temperature.
Is the method for instant cooling of water safe for consumption?
The safety of the method for instant cooling of water depends on the specific cooling agent used and the temperature at which the water is being cooled. It is important to use proper precautions and follow instructions carefully to ensure safe consumption of the cooled water.
Can the method for instant cooling of water be used for any type of water?
Yes, the method for instant cooling of water can be used for any type of water, including tap water, distilled water, or even saltwater. However, the type of water may affect the effectiveness of the cooling process and may require different cooling agents or methods.
Are there any alternative methods for instant cooling of water?
Yes, there are alternative methods for instant cooling of water, such as using a water chiller or adding ice cubes to the water. However, the effectiveness and speed of these methods may vary compared to using a specialized method for instant cooling of water.
