Method of characteristics and second order PDE.
In summary, the method of characteristics can be used to transform a second order PDE into a simpler form by introducing new variables and using the chain rule. This allows us to solve the equation by finding a solution to the simplified form.
peripatein
880
This isn't a homework question per se. Am merely seeking an explanation how the method of characteristics may be applied to a second order PDE. For instance, how is it used to solve utt=uxx-2ut?
That is a "hyperbolic" equation and, ignoring the lower order, first derivative is [itex]u_{tt}= u_{xx}[/itex] so has "characteristic equation"[itex]t^2= x^2[/itex] or [itex]t= \pm x[/itex] so the "characteristics" are [itex]t- x= constant[/itex] or [itex]t+ x= constant[/itex].
That tells us that we can simplify the equation by taking p= t- x and q= t+ x as variables instead of x and t. By the chain rule, [itex]u_t= u_pp_t+ u_qq_t= u_p+ u_q[/itex] and then [itex]u_{tt}= (u_p+ u_q)_t= (u_p+ u_q)_p+ (u_p+ u_q)_q= u_{pp}+ 2u_{pq}+ u_{qq}[/itex].
Similarly, [itex]u_x= u_pp_x+ u_qq_x= -u_p+ u_q[/itex] and then [itex]u_{xx}= (-u_p+ u_q)_x= -(-u_p+ u_q)_p+ (-u_p+ u_q)_q= u_pp- 2u_{pq}+ u_{qq}[/itex].
So [itex]u_{tt}= u_{xx}+ u_t[/itex] becomes [itex] u_{pp}+ 2u_{pq}+ u_{qq}= u_pp- 2u_{pq}+ u_{qq}+ u_p+ u_q[/itex]. The "[itex]u_{pp}[/itex]" and "[itex]u_{qq}[/itex]" cancel, leaving [itex]4u_{pq}= u_p+ u_q[/itex].
FAQ: Method of characteristics and second order PDE.
What is the method of characteristics?
The method of characteristics is a technique used to solve second order partial differential equations (PDEs). It involves transforming the PDE into a system of ordinary differential equations (ODEs) by introducing new variables called characteristic variables. These variables satisfy a set of equations known as the characteristic equations, which can then be solved to obtain a solution to the PDE.
How is the method of characteristics used to solve second order PDEs?
The method of characteristics is used to solve second order PDEs by transforming the PDE into a system of characteristic equations. These equations can then be solved to obtain a solution to the PDE. The method is particularly useful for solving PDEs with initial or boundary conditions, as the characteristic equations can be used to determine the constants of integration.
What types of PDEs can be solved using the method of characteristics?
The method of characteristics is primarily used to solve linear second order PDEs. However, it can also be applied to some non-linear PDEs, depending on the specific form of the equation. In general, the method is most effective for PDEs that are hyperbolic or parabolic in nature.
What are the advantages of using the method of characteristics for solving PDEs?
One of the main advantages of the method of characteristics is that it can be used to solve PDEs with initial or boundary conditions, which are commonly encountered in many scientific and engineering applications. Additionally, the method is relatively straightforward and can be applied to a wide range of PDEs, making it a versatile tool for scientists and mathematicians.
Are there any limitations to using the method of characteristics for solving PDEs?
While the method of characteristics is a powerful tool for solving certain types of PDEs, it does have some limitations. The method is not applicable to all types of PDEs, and in some cases, it may be difficult to determine the characteristic equations or solve them analytically. Additionally, the method may become computationally expensive for more complex PDEs, requiring numerical techniques to obtain a solution.
