MHB MHB Simplify Fraction: 196707/250971
  • Thread starter Thread starter Petrus
    Fraction Simplify
The fraction 196707/250971 can be simplified using the Euclidean Algorithm, which reveals that the greatest common divisor is 6783, reducing the fraction to 29/37. Participants in the discussion shared various methods for simplification, including divisibility tests for numbers like 3, 7, 11, 13, 17, and 19. The calculations confirmed that both the numerator and denominator are divisible by these factors at different stages. Ultimately, the consensus is that the simplest form of the fraction is indeed 29/37. The discussion highlights the effectiveness of the Euclidean Algorithm and divisibility tests in fraction simplification.
Petrus
Hello MHB,
Simplify as far as possible without any calculator $$\frac{196707}{250971}$$
Hint:
Euclidean Algorithm
Regards,
Mathematics news on Phys.org
Petrus said:
Hello MHB,
Hint:
Euclidean Algorithm
Regards,
The Euclidean Algorithm gives us that the greatest common denominator is 6783.
Therefore the fraction simplifies to [math]\frac{29}{37}[/math].
Hello I like Serena,
Thanks for joining the 'challange question'(Cool)! You correctly calculated gcd and simplify! I totaly forgot about this one but I Will post full solution when I got time!:)
Regards
$$|\pi\rangle$$
Here is a way to proceed.
The sum of the digits of both numbers is a multiple of 3 so both numbers are divisible by 3. Divide them both by 3
\frac{65569}{83657}
Clearly neither divisible by 5
break this number up like this 65569 = 065 569 , into groups of 3 digits each , now subtract, 569 - 65 = 504
This gives us at once a divisibility test for 7, 11, and 13
if 504 is divisible by 7, so is 65569
if 504 is divisible by 11 so is 65569
if 504 is divisible by 13 so is 65569
we see 7 divides 504 but 11 and 13 do not
Do the same for 83657 = 083 657 , subtract 657 - 83 = 574
It's easy to see 574 is divisible by 7 since previously 504 was divisible by 7 and this is 70 more than that. No need to test for 11 and 13 since those factors won't cancel if they are there (they are not)
Divide them both by 7.
\frac{9367}{11951}
perform previous procedure again
367 - 9 = 358 not divisible by 7.
Note* Divisibility test for 3 did not have to be done TWICE because sum of digits was NOT 9 but in general you have to repeat the test until divisibility posibility is exhausted.
For divisibility by 17 , cut off the last digit of 9367 , multiply it by 5 , then subtract that from the truncated number.
936 - 35 = 901
If 901 is divisible by 17 then so is 9367 , it is.
Do the same for 11951,
1195 - 5 = 1190
If 1190 is divisible by 17 , then so is 11951 , it is.
Divide them both by 17
\frac{551}{703}
apply divisibility test again for 17
55 - 5 = 50
not divisible by 17 so neither is 551
For divisibility by 19 , cut off the last digit of 551 , multiply it by 2, add that to the truncated number. 55 + 2 = 57
If 57 is ... well you get the idea , it is
Do the same for 703
70 + 6 = 76 is divisible by 19
Divide them both by 19
\frac{29}{37}
It's quite obvious now you can stop.
\frac{65569}{83657}
\frac{9367}{11951}
936 - 35 = 901
1195 - 5 = 1190
\frac{551}{703}
55 - 5 = 50
Do the same for 703
\frac{29}{37}
Hello agentmulder,
Well done and thanks for my 'challange question'(Cool)! I did almost forgot about this method!
Regards,
$$|\pi\rangle$$
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
