MHB Michael h's question at Yahoo Answers (Sum of a series)
  • Thread starter Thread starter Fernando Revilla
    Series
The discussion centers on finding the sum of the series represented by the expression (2n+1)/(n^2(n+1)^2). The transformation of the expression reveals that it can be rewritten as a difference of two convergent series: 1/n^2 and 1/(n+1)^2. By applying the properties of these series, the sum converges to 1. The calculations demonstrate that the series converges effectively, leading to a clear conclusion. The final result of the sum is 1.
Fernando Revilla
MHB
Here is the question:
(2n+1)/(n^2(n+1)^2)
Here is a link to the question:
Find the sum of the series? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello michael h,
We have $(n+1)^2-n^2=2n+1$, so $$\dfrac{2n+1}{n^2(n+1)^2}=\dfrac{1}{n^2}-\dfrac{1}{(n+1)^2}$$ Using that $\displaystyle\sum_{n=1}^{\infty}\dfrac{1}{n^2},\;\displaystyle\sum_{n=1}^{\infty}\dfrac{1}{(n+1)^2}$ are both convergent: $$\displaystyle\sum_{n=1}^{\infty}\dfrac{2n+1}{n^2(n+1)^2}=\displaystyle\sum_{n=1}^{\infty}\left( \dfrac{1}{n^2}-\dfrac{1}{(n+1)^2}\right)=\displaystyle\sum_{n=1}^{\infty}\dfrac{1}{n^2}-\displaystyle\sum_{n=1}^{\infty}\dfrac{1}{(n+1)^2}=\\\displaystyle\sum_{n=1}^{\infty}\dfrac{1}{n^2}-\left(\displaystyle\sum_{n=1}^{\infty}\dfrac{1}{n^2}-\dfrac{1}{1^2}\right)=\left(\displaystyle\sum_{n=1}^{\infty}\dfrac{1}{n^2}-\sum_{n=1}^{\infty}\dfrac{1}{n^2}\right)+1=0+1=1$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
