Michelson-Gale-Pearson Refutation of Stokes-Planck - Help
  • Thread starter one_raven
In summary, the Michelson-Gale-Pearson experiment in 1925 is considered a refutation of the Stokes-Planck theory of gravitational aether drag. According to the Stokes-Planck theory, the aether near a massive body would experience complete dragging, making it indistinguishable from a non-aetheric model. However, the Michelson-Gale-Pearson experiment provided evidence that this was not the case, supporting the theory of relativity instead. The Stokes-Planck theory was a classical interpretation that pre-dated relativity and would have contradicted it if accepted. The conversation was originally posted in the wrong forum and requested to be moved to the Relativity sub-forum for better discussion.
one_raven
203
I'm hoping for some help in understanding how the Michelson-Gale-Pearson experiment in 1925 is held as a refutation of the Stokes-Planck theory of gravitational aether drag.
If I understand the Stokes-Planck theory correctly, complete dragging of the aether near a sufficiently massive body (diminishing at distance, in accordance to the inverse square law as it applies to gravitational force) would be essentially indistinguishable from a complete dragging model. Wouldn't it also be indistinguishable from a non-aetheric model?
Didn't Michelson-Gale-Pearson support that?
What am I missing?
Thanks.
This should be posted in the Special & General Relativity forum.
I wasn't sure, because the Stokes-Planck theory was a classical interpretation that pre-dated Relativity - and, if it were accepted, would have stood in opposition to Relativity.
Can I move it, or does a moderator have to?
Can a moderator move this to the Relativity sub-forum, please?
Maybe it will get a response there.
I can provide some clarification on the Michelson-Gale-Pearson experiment and its relationship to the Stokes-Planck theory of gravitational aether drag.
Firstly, the Michelson-Gale-Pearson experiment was designed to test the concept of aether drag, which was proposed by George Stokes and Max Planck. This theory suggested that the aether, a hypothetical medium through which electromagnetic waves were thought to propagate, would be dragged by the movement of massive bodies such as the Earth. This would affect the speed of light and lead to a measurable difference in the speed of light in different directions.
However, the results of the Michelson-Gale-Pearson experiment did not support this theory. They found that the speed of light was the same in all directions, indicating that the aether was not being dragged by the Earth's movement. This was a significant result that challenged the concept of aether drag and had implications for other theories, including the Stokes-Planck theory.
In relation to your question about the indistinguishability of a complete dragging model and a non-aetheric model, it is important to note that the Michelson-Gale-Pearson experiment did not directly address this issue. However, the results of the experiment did provide evidence against the existence of aether, which is a key component of the complete dragging model. Therefore, the experiment indirectly refuted this model.
In summary, the Michelson-Gale-Pearson experiment did not directly test the Stokes-Planck theory, but its results did challenge the concept of aether drag, which is a key component of this theory. This is why the experiment is often cited as a refutation of the Stokes-Planck theory. I hope this helps to clarify any confusion.
Related to Michelson-Gale-Pearson Refutation of Stokes-Planck - Help
1. What is the Michelson-Gale-Pearson Refutation of Stokes-Planck?
The Michelson-Gale-Pearson Refutation of Stokes-Planck is a scientific experiment conducted in the early 20th century to test the validity of the Stokes-Planck theory, which proposed that the speed of light is affected by the motion of the Earth. The experiment was designed to measure the speed of light in different directions and compare the results to the predicted values based on the Earth's motion.
2. Why is this experiment important?
This experiment was important because it provided evidence that the speed of light is constant in all directions, regardless of the Earth's motion. This refuted the Stokes-Planck theory and supported the theory of relativity proposed by Albert Einstein.
3. How was the experiment conducted?
The experiment involved splitting a beam of light into two perpendicular beams using a half-silvered mirror. One beam was directed along the Earth's motion, while the other was directed perpendicular to it. The two beams were then recombined and the interference pattern was measured to determine the speed of light in each direction.
4. What were the results of the experiment?
The results showed that the speed of light was the same in both directions, which was inconsistent with the predictions of the Stokes-Planck theory. The measured values were also in agreement with the theory of relativity.
5. How did this experiment impact the field of physics?
The Michelson-Gale-Pearson Refutation of Stokes-Planck was a significant milestone in the development of modern physics. It provided strong evidence for the theory of relativity and helped to disprove a widely accepted theory at the time. This experiment also paved the way for further research and advancements in the understanding of the fundamental laws of physics.
  • Beyond the Standard Models
  • Astronomy and Astrophysics
  • Art, Music, History, and Linguistics
  • Quantum Physics
