bcjochim07
- 374
A Michelson interferometer operating at a 600nm wavelength has 2.00 cm glass cell in one arm. To begin, the air is pumped out of the cell and mirror M2 is adjusted to produce a bright spot ant the center of the interference pattern. Then a valve is opened and air is slowly admitted to the cell. The index of refraction of air at 1 atm of pressure is 1.00028. How many bright-dark-bright fringe shifts are observed as the cell fills with air?
To start out the problem, in order to form a bright spot at the center, I think that there must be an equal number of wavelengths going through both arms.
The number of wavelengths in the evacuted glass tube is (.02/6.0e-7)= 33,333
The wavelength of the light in the air is: (6.0e-7)/1.00028 = 5.998e-7
The length of the other arm must then be adjusted to be:
33333= L2/(5.998e-7) L2= 0.01999 m
When the glass tube is filled w/ air, the number of wavelengths will be (.02m)/(5.998e-7) = 33344 wavelengths.
But I'm not sure how to put this into equation form to calculate the number of shifts I will see. Can someone explain this to me? I'm really having a tough time visualizing
