Microcanonical ensemble generalized pressure
In summary, the conversation discusses the pressure in the macrocanonical ensemble and its derivation using the potential ##\bar p = \frac{1}{\beta} \frac{\partial lnZ}{\partial V}##. The confusion arises due to the use of different potentials, with the Landau potential being used in the context of natural variables ##S##, ##T## and ##\mu##. The relation with the internal energy ##U## is given as ##\Phi=U-TS-\mu N##.
Mayan Fung
131
In the discussion of the pressure in macrocanonical ensemble, I found in textbook that:
##dW = \bar p dV## (##dW## is in fact d_bar W, yet I can't type the bar)
The derivation goes like:
##\bar p = \frac{1}{Z} \sum_{r} e^{-\beta E_r} (-\frac{\partial E_r}{\partial V}) = ... = \frac{1}{\beta} \frac{\partial lnZ}{\partial V}##
However, ## E = TdS - pdV## and in macrocanonical ensemble, we have ##T,V,N## as variables. That means ##\frac{\partial E_r}{\partial V} = (\frac{\partial E_r}{\partial V})_{T,N}## but not keeping entropy ##S## constant.
I am confused about why we can use ##\frac{\partial E_r}{\partial V}## in the above derivation
Hi,
Chan Pok Fung said:
That means but not keeping entropy constant.
please, crosscheck that the partial derivative is for S and N constant
https://de.wikipedia.org/wiki/Mikrokanonisches_Ensemble#Druck
(sorry, it was the only wikipedia article with the pressure definition as partial derivative)
Regards,
ORF
It's just using different potentials. It turns out that ##\Phi=-k_B T \ln Z## is the Landau potential with natural variables ##S##, ##T##, and ##\mu##. The relation with the internal energy ##U## is
$$\Phi=U-TS-\mu N.$$
For details see
https://itp.uni-frankfurt.de/~hees/publ/off-eq-qft.pdf
Sect. 2.1.4
Note that in this manuscript I use natural units with ##k_B=1## and in the relativistic context instead of a conserved particle number I use some conserved charge ##Q## (like electric chrage) to introduce a corresponding chemical potential.
Likes ORF
Related to Microcanonical ensemble generalized pressure
1. What is the Microcanonical Ensemble Generalized Pressure?
The microcanonical ensemble generalized pressure is a thermodynamic quantity that describes the average force per unit area exerted by a system in equilibrium when it is in a fixed volume, energy, and particle number. It is a generalization of the traditional pressure concept in thermodynamics, which is defined for systems in equilibrium at constant temperature and volume.
2. How is the Microcanonical Ensemble Generalized Pressure calculated?
The microcanonical ensemble generalized pressure is calculated by taking the derivative of the microcanonical partition function with respect to the volume of the system. This partition function is a mathematical expression that represents the number of microstates (possible configurations) of a system at a given energy, volume, and particle number. The derivative is then multiplied by the Boltzmann constant to obtain the pressure in units of energy per unit volume.
3. What is the significance of the Microcanonical Ensemble Generalized Pressure?
The microcanonical ensemble generalized pressure is an important quantity in statistical mechanics and thermodynamics as it provides a way to characterize the thermodynamic behavior of a system in equilibrium. It allows for the calculation of various thermodynamic properties, such as the internal energy and entropy, and can also be used to determine phase transitions and critical points.
4. How does the Microcanonical Ensemble Generalized Pressure relate to other thermodynamic quantities?
The microcanonical ensemble generalized pressure is related to other thermodynamic quantities through the fundamental equation of thermodynamics, which describes the relationships between various thermodynamic variables. For example, it is related to the internal energy through the equation: P = (1/V)U + (T/V)(∂V/∂T), where P is the pressure, V is the volume, U is the internal energy, and T is the temperature.
5. What are the limitations of using the Microcanonical Ensemble Generalized Pressure?
The microcanonical ensemble generalized pressure is only applicable to systems in equilibrium and assumes that the energy, volume, and particle number are fixed. This may not accurately describe real-world systems, which may not be in equilibrium or have varying energy, volume, and particle number. Additionally, the microcanonical ensemble is not suitable for describing systems with long-range interactions or systems with small numbers of particles.
  • Quantum Physics
  • Thermodynamics
