I Microstates of an atom in an energy state
In "Introduction to Thermal Physics," Schroeder discusses an isolated atom with fixed energy and degenerate microstates, emphasizing that when in contact with a reservoir at constant temperature, energy exchange occurs. This interaction allows the atom to access various microstates, but the likelihood of each state depends on their energy levels. The presence of a reservoir means that the atom is no longer isolated, which can lift some degeneracy among its microstates. The discussion highlights the importance of heat exchange in determining the probability distribution of the atom's states. Understanding this concept is crucial for grasping thermal interactions in physics.
Sebas4
I have a question about a sentence in the book Introduction to Thermal Physics (Daniel v. Schroeder).
So in chapter 6, Schroeder talks about an atom isolated. This means its energy is fixed.
The atom is in some state. The energy states of the atom have degenerated. All microstates with that energy the atom has are equally probable.
Now they are talking about a reservoir with a constant temperature. There is an exchange of energy between the reservoir and the atom.
Then Schroeder says that "In this case, the atom would conceivably be found in any of its microstates, but some will be more likely than others, depending on their energies.". I don't get this sentence.
So there is always heat exchange between the atom and the reservoir?
Because if there is no heat exchange between the reservoir and atom, the atom cannot be found in any of its microstates because the energy is fixed.
I hope someone can clarify this sentence.
Thank you in advance.
- Sebas4.
Science news on Phys.org
This means that there must be an interaction between the recevoir and the atom (otherwise it would be invisible to it). Usually this will lift some of the degeneracy for the no longer isolated atom. Perhaps that is his point...I do not know for sure.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
