MHB Mike's question at Yahoo Answers regarding reduction of order
  • Thread starter Thread starter MarkFL
    Reduction
The discussion focuses on using reduction of order to find a second linearly independent solution to the differential equation y'' + 2y' + y = 0, given that one solution is xe^{-x}. By substituting y(x) = v(x)xe^{-x} into the equation and computing the necessary derivatives, the process leads to a simplified equation. This results in the expression x^2v''(x) + 2xv'(x) = 0, which can be integrated to find v(x) = -c_1/x + c_2. Ultimately, the second solution is determined to be y(x) = e^{-x}, confirming the linear independence of the solutions.
MarkFL
MHB
Here is the question:
The differential equation
$$y''+2y'+y=0$$
has linear independent solutions $e^{-x}$ and $xe^{-x}$. Pretend you only know that $xe^{-x}$ is a solution, and use reduction of order to obtain a second linearly independent solution.
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Mike,
We are given the nontrivial solution:
$$f(x)=xe^{-x}$$
So, let's set:
$$y(x)=v(x)f(x)$$ and substitute for the derivatives of $y(x)$ into the given ODE. Thus, computing the needed derivatives, we find:
$$y'(x)=v(x)f'(x)+v'(x)f(x)$$
$$y''(x)=v''(x)f(x)+2v'(x)f'(x)+v(x)f''(x)$$
Now we need to compute the derivatives of $f(x)$:
$$f'(x)=-xe^{-x}+e^{-x}=e^{-x}(1-x)$$
$$f''(x)=-e^{-x}+(x-1)e^{-x}=e^{-x}(x-2)$$
And so we find:
$$y'(x)=v(x)e^{-x}(1-x)+v'(x)xe^{-x}=e^{-x}\left(v(x)(1-x)+xv'(x) \right)$$
$$y''(x)=v''(x)xe^{-x}+2v'(x)e^{-x}(1-x)+v(x)e^{-x}(x-2)=e^{-x}\left(xv''(x)+2v'(x)(1-x)+v(x)(x-2) \right)$$
Substituting into the original ODE, we find:
$$e^{-x}\left(xv''(x)+2v'(x)(1-x)+v(x)(x-2) \right)+2\left(e^{-x}\left(v(x)(1-x)+xv'(x) \right) \right)+v(x)xe^{-x}=0$$
Since $$e^{-x}\ne0$$ we may divide through by this factor to obtain:
$$xv''(x)+2v'(x)(1-x)+v(x)(x-2)+2v(x)(1-x)+2xv'(x)+v(x)x=0$$
Distribute:
$$xv''(x)+2v'(x)-2xv'(x)+xv(x)-2v(x)+2v(x)-2xv(x)+2xv'(x)+xv(x)=0$$
Combine like terms:
$$xv''(x)+2v'(x)=0$$
Multiply through by $x$:
$$x^2v''(x)+2xv'(x)=0$$
Now the left side is the differentiation of a product:
$$\frac{d}{dx}\left(x^2v'(x) \right)=0$$
Integrate with respect to $x$ to obtain:
$$\int\,d\left(x^2v'(x) \right)=\int\,dx$$
$$x^2v'(x)=c_1$$
$$v'(x)=c_1x^{-2}$$
Integrate again with respect to $x$:
$$\int\,dv=c_1\int x^{-2}\,dx$$
$$v(x)=-c_1x^{-1}+c_2$$
For simplicity, let $c_1=-1$ and $c_2=0$ and so:
$$v(x)=\frac{1}{x}$$
And hence, we find our second linearly independent solution is:
$$y(x)=v(x)f(x)=\frac{1}{x}xe^{-x}=e^{-x}$$
Shown as required.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
