Miller-Bravais scheme for Hexagonal crystals
  • Thread starter murasame
  • Tags
    Crystals
In summary, The conversation discusses calculating the direction vector for a hexagonal crystal. The process involves calculating the line of projection onto the base plane, then onto the a1 and a2 axes, and reducing the ratio of a1 to a2. The line of projection onto the vertical z axis is also calculated and converted using a formula to eventually get the desired vector. However, there is confusion about the independence of the z vector from the ratio of a1 and a2, and it is unclear if the correct vector should be [11 (-2) 1] or [11 (-2) 2]. The conversation also mentions the unique basal pole and other planes and directions in the hexagonal crystal.
murasame
Hello, sorry to bother again but I've been giving this much thought as well and am very confused..
Please refer to the following page:
http://x5.freeshare.us/119fs641427.jpg
If I am supposed to calculate the direction vector for the hexagonal crystal, I was told to:
1) Calculate the line of projection of the vector (from origin to X) onto the base plane
2) Calculate the new line of projection of this projected line with respect to a1 and a2 axis.
3) Reduce the ratio of a1: a2 to the lowest integer
4) Calculate the line of projection of the vector onto the verticle z axis
5) Use the 3-index system to 4-index system formula to convert it and eventually get [11 (-2) 1] for the mentioned vector.
However, this would imply that the z vector is independent of the ratio in a1 and a2 since using this method we would have gotten 0.5 unit length for a1 and a2 and 1 unit length for z. If not, shouldn't it be [11 (-2) 2] instead?
I'm sorry if I sound confusing, because I'm very confused myself as well. But if anyone knows about this, please help, thanks!
I am not sure what one means by the direction vector. There is a unique planar orientation, the basal pole (normal to the basal plane), which is in the c-direction of the hexagonal (hcp) crystal.
Then there are the three a-directions. Besides that, there are prismatic and pyramidal planes and associated directions.
IIRC, there is [11[itex]\bar{2}[/itex]0].
Hello, thank you for reaching out. The Miller-Bravais scheme is a method used to describe the orientation of crystal planes and directions in hexagonal crystals. It involves a 4-index system, where the first three indices represent the direction of the vector and the fourth index represents the plane normal to the vector.
In the case of hexagonal crystals, the a1 and a2 axes are not perpendicular to each other, which can make it confusing to determine the direction of a vector. The steps you have listed are correct, but it is important to remember that the a1 and a2 axes are not independent of each other. This means that the ratio between them will affect the final 4-index representation of the vector.
In step 3, when you reduce the ratio of a1:a2 to the lowest integer, you are essentially finding the direction of the vector with respect to the a1 and a2 axes. This will affect the final 4-index representation, as shown in step 5.
In your example, the vector [11 (-2) 1] is correct. This means that the vector is parallel to the a1 axis and perpendicular to the a2 axis, with a plane normal of 1. The ratio between a1 and a2 is 1:2, which is why the fourth index is 1. This is not the same as the z axis, which is independent of the ratio between a1 and a2.
I hope this helps to clarify any confusion. If you have any further questions, please feel free to ask. Thank you.
FAQ: Miller-Bravais scheme for Hexagonal crystals
1. What is the Miller-Bravais scheme for Hexagonal crystals?
The Miller-Bravais scheme is a system for categorizing and describing the atomic planes and directions within a hexagonal crystal lattice. It is based on a set of three axes, two of which are perpendicular and the third is at an angle of 120 degrees to the others.
2. Why is the Miller-Bravais scheme important in the study of hexagonal crystals?
The Miller-Bravais scheme provides a standardized method for identifying and characterizing the crystallographic structure of hexagonal crystals. This information is essential for understanding the physical and chemical properties of these materials, as well as for predicting their behavior under different conditions.
3. How are the Miller indices determined in the Miller-Bravais scheme?
The Miller indices are determined by identifying the atomic planes and directions within the hexagonal lattice. The three axes of the lattice are labeled a, b, and c, and each plane or direction is represented by its intercepts with these axes. The Miller indices for a plane are denoted as (h,k,l), where h, k, and l are the intercepts on the a, b, and c axes respectively.
4. Can the Miller-Bravais scheme be applied to other crystal systems?
While the Miller-Bravais scheme was originally developed for hexagonal crystals, it can also be applied to other crystal systems such as cubic, tetragonal, and orthorhombic. However, the notation and conventions may differ slightly depending on the crystal system being studied.
5. Are there any limitations to the Miller-Bravais scheme?
One limitation of the Miller-Bravais scheme is that it cannot be used to describe the crystallographic structure of non-periodic or amorphous materials. It is also not suitable for describing twinning or stacking faults within a crystal lattice. In these cases, alternative methods such as diffraction techniques may be used to analyze the crystal structure.
