Millikan's oil drop experiment homework
In summary, the conversation involves a student seeking assistance with several questions related to their studies. The questions involve topics such as measuring electronic charge, interference in light, and using Kirchhoff's laws to solve circuits. The expert provides helpful explanations and advice to help the student understand the concepts and solve the problems.
al_201314
116
Hi everyone I'm stuck with a few questions hopefully I can get some assistance.
1) A student repeating Millikan's oil drop experiment to measure electronic charge used an incorrectly calibrated voltmeter and obtained the following values for charges on the drops:
Charges on drop / 10^-19C
3.9
7.8
9.1
5.2
Using these results what value should he take for the electronic charge, in C?
2) If one of the slits of the standard Young's double slit demonstration of interference in light is painted over so that it only transmit only half the light intensity, why does the dark lines increase in density and bright lines decrease in density?
3) One junction of X of a thermocouple is placed in melting ice at 273K and the other junction Y in steam at 373K. The e.m.f measured is 1.0mV. Now Y is transferred to a bath whose temp is 398K. Assume variation of e.m.f with temp diff is linear, the e.m.f recored will be?
4) See the attachment. The resistance between A and C is 8ohm. What is resistance R?
For 1, I know charges exist in multiples that they are discrete. I assumed all the values given to be from a drop since they stated on oil drop. How then can I find the charge?
For 2, I know bright lines will decrease in intensity as at the bright lines, the total intensity is lower compared to 2 equal intense waves constructive interfering. But why does the dark fringe increase in intensity? Does it mean it becomes darker? Why so?
3) 1.0mV = k(373-273)
E = k(398-273)
Solving, I get the value of E to be 0.125. Answer given was 1.25.
4) I don't know how to start at all. Using kirchhoffs law doesn't seem to provide anything. Any advice? Answer 4ohms.
Sorry for the long post hope someone could lend a helping hand! thanks!
3.9
7.8
9.1
5.2
You must find a charge such that all the numbers you listed are *integer* mulltiples ofthat fundamental charge (there is actually an infinite number of possibilities but usually one consider the largest possible value such that all measurements are integre multiple of thatvalue).
The first thing to try for for the fundamental charge is obviously the smallest measurement, 3.9. But of course, that does not work since the next value, 5.2 is not a multiple of 3.9.
So 3.9 itself is a multiple of the fundamental value.
Obviously, if all those numbers are multiple of the fundamental charge, their *difference* will be a multiple of the fundamental charge. So the next thing to try is to take in your list th two values the closest together and use the *difference* between the two as the fundamental charge. Is it then possible to write all your values as multiple of that difference? If so, that will be your fundamental charge (again, that's not the only solution but that will be the largest possible value for a possible fundamental charge).
PAtrick
Thanks Pat I got it..
Any help for the rest of the questions? Much appreciated thanks!
Suppose the amplitudes are x and y. Then as y decreases x+y decreases but x-y increases. And since Intensity is proportional to Amplitude^2, so Intensity decreases in first case and increases in 2nd.
And check your calculation for 3.
4)You don't need to use KVL for this. Think that you are connecting an imaginary battery between points A and C. You will find that the resistancce of 1 ohm can be removed from the circuit (why ?).
Now you should be able to easily apply the laws for series and parallel combinations to get your answer.
Do you follow ?
Arun
Thanks for the help.
For Q3, I checked and I still got 0.125V. Did you managed to get the given answer?
I'm not very good in electricity hopefully you can help me out further. It can be removed because B would not be connected so it'll be an open circuit there so no current flows?
I've got another question here regarding electricity as well (see attachment). The question is what is the reading of the volmeter? I drew the loops in myself and the currents I1 I2 and I3. But how do I go around solving the voltmeter reading?
Many thanks again in advance.
Correct. Hope you got the answer :wink:
Thanks Arunbg. Any idea on how is it possible to solve for the 3 currents in the above circuit? Or is there any easier or more conventional way of solving this question?
The only sure way is KVL . Use it for the two small loops and remember
I3=I1+I2
However, I'm not sure about the voltmeter. Is its resistance given or is it considered to be an ideal voltmeter (resistance tending to infinity) ?
3) I suggest you check the units.
Arun
I don't understand that last diagram. Is that circled V supposed to be a voltmeter? Stuck in the middle of the circuit?
Oops I apologise for not being clear! The question is what is the reading on the voltmeter? The question didn't say anything about the resistance of the voltmeter. I still can't solve it as even if I had found the currents, how do I find the voltmeter reading?
Sounds like the only thing you can do is treat it as an ideal voltmeter (with infinite resistance), as arunbg pointed out. In that case, what's the value of I2?
You just need to find the total voltage drop across its terminals. Hint: Add up the voltage drops around the loop.
In order to do that, the currents must still be solved in order to find the drop in potentials right? I have
6 = 5(I3) + 10(I1) and
2 = 5(I3)
I solved for I1 to be 2/5A. Is this correct? Sounds weird as if it is so, I3 is also 2/5. I suppose I2 doesn't come into the picture as there is no potential drop for current I2?
Thanks!
The way I interpret this odd voltmeter placement implies that I2 = 0. So I1 = I3.
That should give the potential drop for the 5ohm resistor to be 2V so the voltmeter reading should be 2? In principle, does the voltmeter in this circuit measures the potential drop across the 5ohm resitor ? What if the potential drop there is just say to be 1.5V?
Right.
Don't forget the 2V battery--that's also between the voltmeter terminals.
Find the cumulative voltage drop from one side of the voltmeter to the other.
Sorry I'm still a bit confused here. Should it read 0 or 4 volts? The 5ohm resistor has a 2V drop, and the battery supply is 2V so it should read 0? However the current through the 5ohm resistor is not totally due to the 2V source since I3 passes through the resistor which part of the current is from the 6V source?
The voltage dropped across 5 ohm is only due to the 6V source . However when measuring with the voltmeter, the 2V source comes into play .
Remember that for drops to cancel out each other, the drops should b in the opposite sense, ie don't aid each other .
If you still have trouble, you can think of the 5 ohm resistance as a 2V battery, with terminals marked as per convention and use KVL (trivially).
Arun
After all the help I'm given I hope I'm not getting it wrong aleady. It should read 0V?
Exactly! And given this "cute" result, now we can see the point of the problem. :wink:
(Note: All the current passing through the resistors is due to the 6V battery.)
Thanks everyone again. Now I see what you mean by "cute"!:smile:
Related to Millikan's oil drop experiment homework
1. What is Millikan's oil drop experiment?
Millikan's oil drop experiment is a famous physics experiment conducted by Robert Millikan in 1909 to determine the charge of an electron. The experiment involved measuring the velocity of charged oil droplets in an electric field and using the values to calculate the charge of the droplets and thus the charge of an electron.
2. Why was Millikan's oil drop experiment important?
Millikan's oil drop experiment provided the first accurate measurement of the charge of an electron. This value was crucial in understanding the structure of atoms and helped to confirm the existence of subatomic particles. It also paved the way for future experiments in the field of quantum mechanics.
3. How did Millikan conduct the oil drop experiment?
Millikan's oil drop experiment involved suspending tiny oil droplets in an electric field between two charged plates. By adjusting the strength of the electric field, he was able to measure the velocity of the droplets and calculate their charge using the known values of the electric field and the droplet's mass.
4. What challenges did Millikan face during the oil drop experiment?
One of the main challenges Millikan faced during the experiment was keeping the oil droplets suspended in the electric field for long enough to measure their velocity accurately. He also had to deal with variations in the electric field and air currents in the chamber, which could affect the droplets' movement and give inaccurate results.
5. How did Millikan's oil drop experiment impact the scientific community?
Millikan's oil drop experiment was a groundbreaking achievement in the field of physics. It provided scientists with an accurate measurement of the charge of an electron and furthered our understanding of the structure of atoms and subatomic particles. It also paved the way for future experiments and discoveries in the field of quantum mechanics.
