How Does X-Ray Ionisation Impact Millikan's Oil Drop Experiment?
In summary, the use of X-ray in Millikan's oil drop experiment is to ionize the oil, which helps create charge. However, this can also lead to errors in calculation as the oil drop becomes attracted upward with increasing charge. The X-ray tube was used to charge the oil drops, but there is a limit to how much charge can be removed and the tube can be turned off before the experiment begins. Without the use of X-rays, the experiment would not be possible.
curious bishal
What is the use of X-ray in Millikan's oil drop experiment? It ionises the oil but what does the ionisation help in? If it creates charge, then the oil's charge keep on increasing it creates error in calculation as the oil drop is attracted upward after sufficient amount of charge.
The X-ray tube was used to charge the oil drops.
There is a limit to how much charge can be removed from the drop by x-rays and, anyway you can always turn the tube off before doing the experiment.
Without something to charge the drops, there would be no experiment.
Related to How Does X-Ray Ionisation Impact Millikan's Oil Drop Experiment?
1. What is Millikan's oil drop experiment?
Millikan's oil drop experiment was a famous experiment conducted by American physicist Robert A. Millikan in 1909 to determine the charge of an electron.
2. How did Millikan conduct the experiment?
Millikan used a chamber filled with air and a fine mist of oil droplets. By applying an electric field, he was able to measure the force acting on the oil droplets and calculate the charge of each droplet.
3. What were the key findings of the experiment?
Millikan's experiment determined the charge of an electron to be 1.602 x 10^-19 coulombs, which is very close to the current accepted value. It also confirmed the existence of discrete, individual charges rather than a continuous charge.
4. What was the significance of Millikan's oil drop experiment?
The experiment was crucial in furthering our understanding of electricity and the nature of the electron. It also provided strong evidence for the existence of quantized charges, which eventually led to the development of quantum mechanics.
5. Are there any controversies surrounding the experiment?
There have been some controversies surrounding Millikan's experiment, including accusations of data manipulation and inconsistencies in his methods. However, the experiment's fundamental findings have been replicated and confirmed by subsequent studies, solidifying its place in the history of science.
  • Other Physics Topics
