Min carrier frequency in Amp Mod.
In summary, the minimum usable value of ωc or f0 in a DSB-SC system with a message limited to B Hz is at least twice the message frequency to avoid any sideband having a bandwidth of 0Hz or less. The Nyquist theory (sampling) can be applied to determine this minimum value. Additionally, the lower sideband is assumed to be a spot frequency with zero bandwidth.
scubaman
Given a DSB -SC system, with a message limited to B Hz, what is the minimum usable value of ωc or f0 (carrier frequency)
Nyquist theory? Not sure how to apply.
Only attempt has been through research.
Hint: we don't want any sideband frequency of 0Hz or less.
What does this have to do with sidebands? A sideband could only have a bandwidth of 0Hz or less if Wc was actually less than Wm, no? I applied the nyquist theory (sampling) to this, and concluded that the carrier frequency must be at least twice that of the message frequency. Not sure if this is right though.
You're getting very warm.
BTW the lower sideband does not "have a bandwidth". It's assumed to be a spot frequency with zero bandwidth.
The minimum carrier frequency for an amplitude modulation system is twice the bandwidth of the message signal. This is known as the Nyquist rate and is derived from the Nyquist-Shannon sampling theorem. Therefore, in this DSB-SC system, the minimum usable value for the carrier frequency would be 2B Hz. This ensures that the message signal can be accurately reconstructed from the modulated signal.
Related to Min carrier frequency in Amp Mod.
1. What is the minimum carrier frequency in Amplitude Modulation?
The minimum carrier frequency in Amplitude Modulation is the lowest frequency that can be used to modulate the amplitude of the carrier wave. It is typically determined by the bandwidth of the modulating signal.
2. How is the minimum carrier frequency calculated in Amplitude Modulation?
The minimum carrier frequency in Amplitude Modulation is calculated by multiplying the highest frequency component of the modulating signal by 2. This ensures that all the frequency components of the modulating signal are included in the modulated signal.
3. What happens if the minimum carrier frequency is not high enough in Amplitude Modulation?
If the minimum carrier frequency is not high enough in Amplitude Modulation, the modulated signal will not accurately represent the modulating signal. This can result in distortion and loss of information in the transmitted signal.
4. Can the minimum carrier frequency be higher than necessary in Amplitude Modulation?
Yes, the minimum carrier frequency can be higher than necessary in Amplitude Modulation. In fact, using a higher carrier frequency can result in a higher quality modulated signal with less distortion and interference.
5. How does the choice of minimum carrier frequency affect the bandwidth in Amplitude Modulation?
The choice of minimum carrier frequency in Amplitude Modulation directly affects the bandwidth of the modulated signal. A higher minimum carrier frequency will result in a wider bandwidth, while a lower minimum carrier frequency will result in a narrower bandwidth.
  • Electrical Engineering
