Min Value of $\dfrac{x}{y}-\dfrac{123}{2014}$: $\dfrac{1}{3792362}$
  • MHB
  • Thread starter anemone
  • Tags
    Value
In summary, the minimal value of $\left|\dfrac{x}{y}-\dfrac{123}{2014}\right|$ is $\dfrac{1}{3792362}$ when $x = 115$ and $y = 1883$, and for all other values of $x$ and $y$ (with $y<2014$), the minimal value is greater than $\dfrac{1}{3792362}$. This can be shown by factoring the numbers and using Euclid's algorithm to find the smallest possible value for the left side of the equation.
anemone
MHB
POTW Director
3,883
115
If $x,\,y$ are positive integers with $y<2014$, show that the minimal value of $\left|\dfrac{x}{y}-\dfrac{123}{2014}\right|$ is $\dfrac{1}{3792362}$.
Mathematics news on Phys.org
[sp]First, factorise those numbers to find that $123 = 3\times41$, $2014 = 2\times19\times53$ and $3792362 = 1883\times2014$.
So the problem is to show that $\left|\dfrac{x}{y}-\dfrac{123}{2014}\right| \geqslant \dfrac{1}{1883\times 2014}$ whenever $y<2014$, and that equality can be achieved.
Let's look first at whether equality can be achieved, so that $\left|\dfrac{x}{y}-\dfrac{123}{2014}\right| =\dfrac{1}{1883\times 2014}$. That is equivalent to $\bigl|\,2014x - 123y\,\bigr| = \dfrac y{1883}.$
Since $123$ and $2014$ are co-prime, the left side of that equation can never be zero when $y<2014$. But it is an integer, so the smallest value it can take is $1$. A routine application of Euclid's algorithm shows that for $y<2014$ this can only happen if either (i) $x=8$ and $y=131$ or (ii) $x = 115$ and $y = 1883$. In case (i), $\bigl|\,2014x - 123y\,\bigr|$ is much larger than $\dfrac y{1883}.$ But in case (ii), equality occurs.
For any other values of $x$ and $y$ (with $y<2014$), we must have $\bigl|\,2014x - 123y\,\bigr| \geqslant2$, and $\dfrac y{1883} <2$. Therefore $\bigl|2014x - 123y\bigr| > \dfrac y{1883}$ and consequently $\left|\dfrac{x}{y}-\dfrac{123}{2014}\right| > \dfrac{1}{3792362}$.
Therefore $\dfrac{1}{3792362}$ is the minimal value, and it only occurs when $x = 115$ and $y = 1883$.[/sp]
Very well done, Opalg!(Happy) And thanks for participating!(Smile)
FAQ: Min Value of $\dfrac{x}{y}-\dfrac{123}{2014}$: $\dfrac{1}{3792362}$
What is the minimum value of the expression $\dfrac{x}{y}-\dfrac{123}{2014}$ when $\dfrac{1}{3792362}$ is substituted for $\dfrac{x}{y}$?
The minimum value of the expression is -\dfrac{1}{3792362}.
How do you determine the minimum value of this expression?
To determine the minimum value of this expression, you can use the concept of derivatives. By taking the derivative of the expression with respect to either x or y, setting it equal to 0 and solving for the variable, you can find the minimum value.
Can you find the minimum value without using derivatives?
Yes, you can also use the concept of completing the square. By rearranging the expression and completing the square, you can find the minimum value without using derivatives.
Is the minimum value a unique solution?
Yes, the minimum value is a unique solution. This means that there is only one value of x and y that will result in the minimum value of the expression.
Can the minimum value be negative?
Yes, the minimum value can be negative. This will occur when the value of x is negative and y is positive or vice versa, resulting in a negative value for the expression.
