JD_PM
- 1,131
- 158
- Homework Statement
- By making the minimal substitution
$$\partial_{\alpha} \phi(x) \rightarrow D_{\alpha} \phi(x) = \Big[\partial_{\alpha} + \frac{ie}{\hbar c} A_{\alpha} (x) \Big] \phi(x)$$
$$\partial_{\alpha} \phi^{\dagger}(x) \rightarrow [D_{\alpha} \phi(x)]^{\dagger} = \Big[\partial_{\alpha} - \frac{ie}{\hbar c} A_{\alpha} (x) \Big] \phi^{\dagger}(x)$$
In the Lagrangian density ##\mathscr{L} = \partial_{\alpha} \phi \partial^{\alpha} \phi^{\dagger} - \mu^2 \phi \phi^{\dagger}## (where we'll have to normal-order* the operators ##\phi(x), \phi^{\dagger}(x)##) of the complex KG scalar field ##\phi(x)##.
a) Derive the Lagrangian density ##\mathscr{L}_I (x)## for the interaction of the charged bosons, described by the field ##\phi(x)##, with the electromagnetic field ##A^{\alpha} (x)##
b) Assuming that ##\mathscr{L}_I (x)## is invariant under the charge conjugation transformation ##\mathscr{C}##, show that
$$\mathscr{C} A^{\alpha} (x) \mathscr{C}^{-1}=-A^{\alpha}(x)$$
* Let me clarify what I mean by 'normal-order': we place all absorption operators to the right of all creation operators.
- Relevant Equations
- $$\partial_{\alpha} \phi(x) \rightarrow D_{\alpha} \phi(x) = \Big[\partial_{\alpha} + \frac{ie}{\hbar c} A_{\alpha} (x) \Big] \phi(x)$$
More below
a) I think I got this one right. Please let me know otherwise
We have (let's leave the ##x## dependence of the fields implicit )
$$\mathscr{L} = N \Big(\partial_{\alpha} \phi \partial^{\alpha} \phi^{\dagger} - \mu^2 \phi \phi^{\dagger} \Big) = \partial_{\alpha} \phi^{\dagger} \partial^{\alpha} \phi - \mu^2 \phi^{\dagger} \phi$$ $$=\Big[\partial_{\alpha} - \frac{ie}{\hbar c} A_{\alpha} \Big]\phi^{\dagger}\Big[\partial^{\alpha} + \frac{ie}{\hbar c} A^{\alpha} \Big]\phi - \mu^2 \phi^{\dagger} \phi$$
We now expand it out to get
$$\mathscr{L} = \partial_{\alpha} \phi^{\dagger}\partial^{\alpha} \phi - \Big(\frac{ie}{\hbar c}\Big)^2 A_{\alpha}A^{\alpha} \phi^{\dagger} \phi + \Big(\frac{ie}{\hbar c}\Big) A^{\alpha} (\partial_{\alpha} \phi^{\dagger}) \phi - \Big(\frac{ie}{\hbar c}\Big) \phi^{\dagger} A^{\alpha} (\partial_{\alpha} \phi)- \mu^2 \phi^{\dagger} \phi$$ $$=(\partial_{\alpha}\partial^{\alpha} - \mu^2)\phi^{\dagger} \phi + \frac{ie}{\hbar c} A_{\alpha}\Big( (\partial^{\alpha} \phi^{\dagger})\phi - \phi^{\dagger} (\partial^{\alpha} \phi) \Big)+\Big(\frac{e}{\hbar c}\Big)^2 A_{\alpha}A^{\alpha} \phi^{\dagger} \phi = \mathscr{L}_0 + \mathscr{L}_I$$
Where
$$\mathscr{L}_0 = (\partial_{\alpha}\partial^{\alpha} - \mu^2)\phi^{\dagger} \phi$$
$$\mathscr{L}_I = \frac{ie}{\hbar c} A_{\alpha}\Big( (\partial^{\alpha} \phi^{\dagger})\phi - \phi^{\dagger} (\partial^{\alpha} \phi) \Big)+\Big(\frac{e}{\hbar c}\Big)^2 A_{\alpha}A^{\alpha} \phi^{\dagger} \phi \tag{*}$$
So ##(*)## is the answer.
b) Here I assumed that ##(*)## is correct. I know from exercise ##(3.5)##, which I have previously solved, that
$$\phi \rightarrow \mathscr{C} \phi \mathscr{C}^{-1}=\eta_c \phi^{\dagger} = \phi^{\dagger}$$
$$\phi^{\dagger} \rightarrow \mathscr{C} \phi^{\dagger} \mathscr{C}^{-1}=\eta_c^* \phi = \phi$$
Where
- ##\mathscr{C}## is a unitary operator which leaves the vacuum invariant ##\mathscr{C} |0 \rangle = |0 \rangle##
- The phase factor ##\eta_c## is arbitrary and it is customary to set it equal to ##1##.
My idea was to sandwich ##\mathscr{L}_I## with the unitary operator but I am having troubles to get the desired answer. Before posting the whole detailed attempt I'd like to kindly ask
1) Is the following correct
$$\mathscr{C} \phi^{\dagger} \phi \mathscr{C} = \mathscr{C} \phi^{\dagger} \mathscr{C} + \mathscr{C} \phi \mathscr{C} = \phi + \phi^{\dagger}\rm \,\,\,?$$
2) Is ##(*)## correct?
Thank you
Where
Where
Thank you
